8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible),
57
Mod | | | Forums66 Topics128,075 Posts1,055,919 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Any tips or tricks? Just got a rebuilt one last night with the right gasket. Choke cable bracket was included.
Looks good and I'm going to toss it on tonite. I assume I'll just use the old insulator. It is going on a 55 235.
Mapleleaf | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Need I ask: please post a driving report after you get it running and tuned?
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | All you should have to do is adjust the idle speed & mixture. Like TC I'd like to know how it runs. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | One question I have - I'm still learning - is where to pull off the vacuum for setting it up. I guess I could pull out the threaded iron plug below the carb and stick a barbed fitting in the intake manifold until I got it set up.
But I may just set it up by ear. | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Well..preliminary report is very good...I stuck it on and the truck ran very smoothly. I could not get the idle down past 700 but it was a very cold and wet day (ad it got colder). I put it on the day the truck had to go into winter storage (1.5 hours away in the Valley area) and I have not had a chance to look at anything else on the engine (timing, valve adjustment, etc...) That will have to wait until the spring. I've got a Langdon dist that I'm considering installing as well.
I'm comparing this to a badly set up Rochester B that looks like it has a warped cover. The first Rochester B I took off had a very bad casting - some of the internal mating surfaces were marred and the accelerator pump fit very loosely inside the bowl (and the piston was new). It was rebuild so I guess they just used the old worn casting. Too bad.
I set out with the truck to the storage garage and hit a major temperature drop along my trip...got caught in a fairly large flurry and temperature dropped well below freezing as I got high in the hills. The truck ran great - lots of power, good response, no lag, fuel economy was much better as well. The only problem I had was when I stopped to top up the tank, the only way I could get it started again was by holding the pedal to the floor. It also shut off as I turned off the highway.
My buddy thinks it was a product of driving along in a wet, freezing temperature at 60mph with no heat duct going to the carb. When I got off on the side roads, moving along at 30mph and out of the wind, the truck idled great (at 700+) and started right up again easily so he may be right.
Overall? 2 conditional thumbs up so far. Thanks to Jon (carbking) for the advice. But then again, I did not have the best of 1b's to test against.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | The truck wants to move south
Dennis -there is nothing stronger than the heart of a volunteer-
