4 members (Oswald, treegrower, Nick in Manitou, 1 invisible), 40 guests, and 3 robots.
Topics128,076
Posts1,055,920
Members48,429
#983847 11/05/2013 8:12 PM
Any tips or tricks? Just got a rebuilt one last night with the right gasket. Choke cable bracket was included.
Looks good and I'm going to toss it on tonite. I assume I'll just use the old insulator. It is going on a 55 235.
Mapleleaf
Need I ask: please post a driving report after you get it running and tuned?
Riding in the Passing Lane
All you should have to do is adjust the idle speed & mixture.
Like TC I'd like to know how it runs.
1972 Chevy c10 Cheyenne Super
One question I have - I'm still learning - is where to pull off the vacuum for setting it up. I guess I could pull out the threaded iron plug below the carb and stick a barbed fitting in the intake manifold until I got it set up.
But I may just set it up by ear.
Well..preliminary report is very good...I stuck it on and the truck ran very smoothly. I could not get the idle down past 700 but it was a very cold and wet day (ad it got colder). I put it on the day the truck had to go into winter storage (1.5 hours away in the Valley area) and I have not had a chance to look at anything else on the engine (timing, valve adjustment, etc...) That will have to wait until the spring. I've got a Langdon dist that I'm considering installing as well.
I'm comparing this to a badly set up Rochester B that looks like it has a warped cover. The first Rochester B I took off had a very bad casting - some of the internal mating surfaces were marred and the accelerator pump fit very loosely inside the bowl (and the piston was new). It was rebuild so I guess they just used the old worn casting. Too bad.
I set out with the truck to the storage garage and hit a major temperature drop along my trip...got caught in a fairly large flurry and temperature dropped well below freezing as I got high in the hills. The truck ran great - lots of power, good response, no lag, fuel economy was much better as well. The only problem I had was when I stopped to top up the tank, the only way I could get it started again was by holding the pedal to the floor. It also shut off as I turned off the highway.
My buddy thinks it was a product of driving along in a wet, freezing temperature at 60mph with no heat duct going to the carb. When I got off on the side roads, moving along at 30mph and out of the wind, the truck idled great (at 700+) and started right up again easily so he may be right.
Overall? 2 conditional thumbs up so far. Thanks to Jon (carbking) for the advice. But then again, I did not have the best of 1b's to test against.
The truck wants to move south
Dennis
