4 members (Wayne67vert, MickeyP, Otto Skorzeny, Bill Hanlon), 176 guests, and 0 robots.
Topics128,106
Posts1,056,213
Members48,436
My 53 Chevy pass door has an outer door glass window rubber stapled to the door. Is this the correct rubber and where can I find the staples? Also is there still a tool made to install the staples?
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
Mike, those rubber strips just slide into the "channel". I've never seen them stapled in. On mine I put them in and pinched the end of the channel a little so it would "crawl" out the ends.
Now the "fuzzy" strips are stapled in. I glued mine in with super weatherstrip adhesive and have had no problem for two years.
The vendors do sell the staples for putting the fuzzies on.
It'd be good for you to view Denny Grahams picture trail of him doing his originally with the staples.
...and I hope we're talking about the same things smile
Thanks Alvin, I should have checked Denny's site first.
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
Alvin's got it covered, the rubber just slides in but the cats
whiskers get stapled in. You can buy the staples from the
vendors but they are not the correct width for the original
holes. I made a die set to bend up a batch on the correct
center line:
http://www.pbase.com/dennygraham/image/123537640
Step thru the 'next' four photos and it shows you what you have
to go thru to transfer the holes to the channel and install
them with the staples.
Denny G
Denny G
Sandwich, IL
Moderated by  ndkid275, Phak1
