0 members (),
108
8
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 1,044 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,044 | My '42 Chevy pickup never had the original seat back. Currently I have a piece of plywood that has been upholstered. Recently, I came across a decent seat back frame and springs. At the top there are two hooks which fit nicely into slots in the cab sheet metal below the rear window.
At the bottom of the seat there are two extensions or tabs that stick down. When the seat back is hung in the slots, these tabs don't engage with anything. They are too short to reach the seat bottom base.
Am I missing some sheet metal or does the seat back just hang from the top hooks?
| | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | On my 46 those seat stakes at the bottom of the seat back mate into tabs that stick out from your seat bottom. Mine were covered up with excess naugahide till I dug them out. | | | | | Joined: Apr 2007 Posts: 1,044 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,044 | Elmer46, Thanks, you are correct. I found the tabs on my seat bottom, which were hidden by excess naugahide, as well. Of course, it makes sense to me now, in that when you slide the bottom closer to the front, the seat back will stay attached and swing a little forward also. Thanks, you answered my question.
Kent | | |
