3 members (moparguy, stlcardinalsguy, Cosmo), 141 guests, and 0 robots.
Topics128,101
Posts1,056,182
Members48,436
#985172 11/10/2013 11:14 PM
V
V Offline
Been working my new switch and rebuilt heater/defroster lately and that switch definitely runs hot.
it's a variable resistance type switch and it runs hotter when it's turned down to run the 6v motor slow. It smoked the 1st couple times I ran it but it seems to have burnt off whatever packing/grease etc that may have been on it when new. It still gets so hot that you can't touch the porcelain and metal backing.
Is this SOP for this setup?
Dave
Leo Offline
Moderator
Moderator
Mine's like that too, red hot! I was told this is normal.
Ex Hall Monitor
Ex Hall Monitor
That is the way they are designed. The lower speed of the motor is the result of current being shunted away and dissipated as heat by the switch.
8
8 Offline
MIne does it too.
Past thread on the topic.
Curt Warren
Salt Lake City
1948 1.5ton Loadmaster
http://photobucket.com/48loadmaster
V
V Offline
Originally Posted by 801curt
MIne does it too.
You know, I did a search for heater switch and smoking switch and your thread didn't come up in either. Course I only went back about 5 or 6 threads in both results and didn't come up with a thing related to what I was searching for.
But mine is doing just as your's did. My light is bright when set on high also.
Looks like it's SOP for these switches to run hot.
Dave
