| | | Forums66 Topics128,095 Posts1,056,067 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Been working my new switch and rebuilt heater/defroster lately and that switch definitely runs hot. it's a variable resistance type switch and it runs hotter when it's turned down to run the 6v motor slow. It smoked the 1st couple times I ran it but it seems to have burnt off whatever packing/grease etc that may have been on it when new. It still gets so hot that you can't touch the porcelain and metal backing. Is this SOP for this setup? Dave | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Mine's like that too, red hot! I was told this is normal. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | That is the way they are designed. The lower speed of the motor is the result of current being shunted away and dissipated as heat by the switch.
| | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | You know, I did a search for heater switch and smoking switch and your thread didn't come up in either. Course I only went back about 5 or 6 threads in both results and didn't come up with a thing related to what I was searching for. But mine is doing just as your's did. My light is bright when set on high also. Looks like it's SOP for these switches to run hot. Dave | | |
