| | | Forums66 Topics128,211 Posts1,057,471 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 54 | I was just wondering if anyone has ordered one and if so were you happy with it? Found one on eBay for 300 bucks from Jim Carter. Thanks
..."some gave all, KIA"...
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Jim Carter is selling the 1/2 ton gas tank, it is not the same as the one ton. 16 gallon for the 1/2 ton and 18 gallons for the 1 ton. previous topic | | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | I was unable to find a tank for my panel. But some shops, such as radiator shops, will cut the tank open, clean and repair rust, then reassemble the tank and coat the inside with an epoxy material. That is what I ended up doing. The shop who did mine offered a lifetime warranty. It's been about 4 yrs and so far it's been working just fine. The owner of the shop told me it is used widely on commercial trucks. The cost is comparable to that what a new tank cost for those that are available.
| | | | | Joined: Sep 2007 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 54 | Beautiful truck Ned and thanks for the info.
Yes gmoniz, I thought that might be to good to be the one I needed. Thanks for the heads up.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ... I think I got one of the first tanks Jim had remade for the half ton. It is a nice tank down to the last dimple it matches the old one.
Has he, by chance, had the one ton duplicated?? Give him a call and ask! .... AND he may have a nice used one out back where he has a lot of fenders and doors and such. I wanted to bring it all home with me! | | | | | Joined: May 2010 Posts: 74 'Bolter | | 'Bolter Joined: May 2010 Posts: 74 | | | |
