5 members (frogfarmer, baldeagle, Otto Skorzeny, tclederman, Rusty Heaps), 62 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,419
#983267 11/02/2013 8:38 PM
So who has power steering and what gear box are you using or did you tap the original
In reference to what year/model truck?
1952 Chevrolet 3800 pickup
---All pictures---
1948 4400 but it has a 389 v8 in it. Im just wondering what box people are using
Crusing in the Passing Lane
I don't think there is a power steering box that fits all AD trucks, every situation is different.
I converted my '47, first series to 4WD, outside the frame, cross over steering, Scout Saginaw box.
My '37 GMC got a P3500HD front axle(5 and 10 lug wheels) w/ disc brakes, factory P3500HD Saginaw box, mounted outside frame, fore and aft motion, drag link shortened 1", other wise stock linkeage.
Saginaw GM boxes are pretty much the same, just use different pitman arms for crossover(4WD) or fore and aft(2WD) steering. If one takes any pitman arm and small 3 corner file, remove the factory skip spline, then can be used either way.
GM factory frames frequently crack from power steering stresses, it is useful to make a frame doubler to spread out some of these loads, use all 4 mounting bolt locations if present, as well as taking care of mounting obstacles.
My 56 has a scout box and cross over steering.
If you can make the link to my photo bucket account work there are many pictures of my steering system there.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Most of the PS upgrades I've seen to older units have been all over the place and just "made to work". I'm having to go that route on my '46 skool bus. The original box was inside the frame and in the way of the new motor (a Cummins 4BTAA) so I'm working on installing an Isuzu NPR unit that fits on the outside of the frame. Lots of building to do but hey...
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
