1 members (baldeagle),
38
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | So in all my searching I haven't found any specific threads about rebuilding a dump bed or completely replacing one. Do most people just put on a flatbed and call it good. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | What part of the bed needs rebuilding? The box the ram or the sub frame??? There are so many different manufacturers that for the most part it is a mater of fabrication. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I've done both the rebuilding and replacing many times and may be of some help to you. Roy is correct about it usually being a fab job and it's not likely to be a straight off with the old and on withthe new which would be too easy.
Give us more detail and pictures or a thorough desdcription of what your needing. | | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | All of the wood and framing is going to need replaced. PTO and ram seem fine but all the wood is rotted and falling off. The pics are in my album.https://plus.google.com/photos/103651644171441676100/albums/5873521037161100257?banner=pwa | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | First of all it is not a dump bed. It is a wooden platform body with a hoist. Big, big difference. Not to make a big deal out of terminology but we might as well start by being correct.
Secondly, yes just replace the platform body. If you choose to make one then you've already got the pattern in front of you and it coule be built from kiln dried white oak for the structure and dense southern YP for the floor. Use screws and bolts and please..no nails.
Same desigbn will work if you use steel and the longsills should be 7/8" C channel, crossmembers can be structural 3-4" channel or fabricated channel. Use the dimensions on the current wooden body. | | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | Are you sure your bed is shot? I thought mine was rough but I have had no problems filling, and dumping it. '48 Loadmaster grainbed with hoist | | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | For what I need its shot. The wood is missing chunks and it can be broken by hand. There is thin sheet metal covering the holes. The posts that go through the bed to hold the sides up is rotten and rigged back together. 53moneypit do you have pictures of the different parts. I can see replacing the platform, which I'm assuming is the actual deck, but the lower part that holds the ram itself looks like its cracked length wise. Only way to tell anything is to rip it off and see how bad it is. Just wanting to do research and make sure I don't kick myself in the [censored]. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Really not sure what you want. Do you want to buy one or build one? | | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | Probably build one. I want to keep it stock looking but modern. Still keep the 14'x8' with removeable 4' sides and keep the dump. I just think that I need to build from scratch. Just looking for pictures, ideas, problems I may run into, cost things like that | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Send me your private e-mail address and I'll forward a bunch of stuff you can use, OK? Thanks | | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | Pm sent thank you moneypit | | |
