4 members (Bill Hanlon, Chip O, walter74, Gdads51), 180 guests, and 2 robots.
Topics128,039
Posts1,055,591
#982488 10/30/2013 10:24 AM
I have a 53 chevy truck and I had the steering box rebuilt and the steering is tighter coming off the center as you go left its smoother then back to right it's smooth until you pass through center then it tighter untill it passes over center then it's smooth going to the rest of the way
Going right. I have not added lubricant to the box yet is that something that will smooth it self out with lube and some use ? Also any suggestion to what kind of lube to use in steering box I was told grease but not sure ?
sal moreno #982498 10/30/2013 12:49 PM
You should get some grease into the box, John Deere corn head grease is the closest to the original spec for the box. It sounds like the box needs to be adjusted. If you look in the service manual it explains the steps to do it. You will need a pull type fish scale to do it and they can be had at Wal Mart - K Mart type stores. Make sure that you have the box in the center of its travel when you start your adjustments. When the box is on center its at its tightest point.
Ok I'll try that .. What type of grease do I get u mention John deer corn head ?
sal moreno #982596 10/30/2013 9:04 PM
John Deere Corn Head Grease. Any John Deere dealer should have this in stock.
Bill Burmeister
sal moreno #982638 10/31/2013 12:37 AM
3B Offline
Hy sal moreno, a properly adjusted steering box will be slightly tighter traveling through the center of its travel (wheels straight ahead position), if it checks out okay with the "fish scale" pull test then leave the adjustment alone, hope that helps.
sal moreno #982662 10/31/2013 1:51 AM
A trigger pull scale works very nice for this job.
3B #982708 10/31/2013 3:16 AM
Ok I will put the corn head grease in it .. How much grease should I put in the steering box ?
sal moreno #982714 10/31/2013 3:53 AM
Fill it to the bottom of the pipe plug hole. Do not pressure feed the self-leveling grease - that could force the grease up the the steering gear tube, right up to the horn button (as warned/described in the Operator's Manual).
sal moreno #982717 10/31/2013 4:15 AM
tclederman #982751 10/31/2013 11:55 AM
I'm not sure what they mean don't pressure fill the gear box . How I'm I suppose to fill it with grease ? Do I just take the pipe plug out and stick a grease gun hose in the hole and just fill with grease until it comes out ?
sal moreno #982764 10/31/2013 1:57 PM
That sounds good. It will be a thick but self-leveling grease.
Fill it to the plug and then wait a while for the grease to level out. Then, top it up into the plug hole.
sal moreno #982768 10/31/2013 2:02 PM
I wonder if "knuckle pudding " would work? Over at the Willy groups the guys mix 90 weight oil with grease half and half to put in the universal balls on the front 4wd axles. Say it stays in better, doesn't leak past the seals on the ball.
Yep, that should work fine. That is what I did, but I used 120 weight gear oil and bearing grease. Mixed to self leveling consistency that I felt would still allow adequate lubrication to the top bearing.
LONGBOX55 #1067886 11/12/2014 9:17 AM
What type of grease is it just general corn head grease
A corn head grease is the correct consistency. John Deere sells it by the tube. People have posted other sources.
I ordered cornhead from these guys
http://www.greenpartstore.com/John-Deere-Special-Purpose-Corn-Head-Gun-Grease-AN102562.html
By the way, can someone tell me how to shorten and rename a url like above?
Dennis
40 Chevy 1/2 ton
DennisM #1067911 11/12/2014 3:22 PM
Press "Reply"
Use the second icon from the left (above the edit "window" - the icon is a globe with two chain-links under the globe.
Put the URL in the first box and then press "OK"
Put the words/description in the next box and press "OK"
You can then edit the words/description, if you want to do so.
Thank you Tim.
Dennis
40 Chevy 1/2 ton
1 Offline
This pipe plug is the fill plug on the top of the steering box correct?
1942 BK 1/2 Ton Pickup
1954 3800 1 Ton Pickup
1942?
Yes, it is a/the pipe plug.
Fill to just below below the base of the hole.
Drive/steer the truck.
Re-check the level and fill to just below the pipe hole.
http://chevy.oldcarmanualproject.com/shop/1942/42csm0011.htm
