| | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | I have a 53 chevy truck and I had the steering box rebuilt and the steering is tighter coming off the center as you go left its smoother then back to right it's smooth until you pass through center then it tighter untill it passes over center then it's smooth going to the rest of the way Going right. I have not added lubricant to the box yet is that something that will smooth it self out with lube and some use ? Also any suggestion to what kind of lube to use in steering box I was told grease but not sure ? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You should get some grease into the box, John Deere corn head grease is the closest to the original spec for the box. It sounds like the box needs to be adjusted. If you look in the service manual it explains the steps to do it. You will need a pull type fish scale to do it and they can be had at Wal Mart - K Mart type stores. Make sure that you have the box in the center of its travel when you start your adjustments. When the box is on center its at its tightest point. | | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | Ok I'll try that .. What type of grease do I get u mention John deer corn head ? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | John Deere Corn Head Grease. Any John Deere dealer should have this in stock.
Bill Burmeister | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy sal moreno, a properly adjusted steering box will be slightly tighter traveling through the center of its travel (wheels straight ahead position), if it checks out okay with the "fish scale" pull test then leave the adjustment alone, hope that helps. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | A trigger pull scale works very nice for this job.
| | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | Ok I will put the corn head grease in it .. How much grease should I put in the steering box ? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Fill it to the bottom of the pipe plug hole. Do not pressure feed the self-leveling grease - that could force the grease up the the steering gear tube, right up to the horn button (as warned/described in the Operator's Manual). | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | I'm not sure what they mean don't pressure fill the gear box . How I'm I suppose to fill it with grease ? Do I just take the pipe plug out and stick a grease gun hose in the hole and just fill with grease until it comes out ? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That sounds good. It will be a thick but self-leveling grease.
Fill it to the plug and then wait a while for the grease to level out. Then, top it up into the plug hole.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I wonder if "knuckle pudding " would work? Over at the Willy groups the guys mix 90 weight oil with grease half and half to put in the universal balls on the front 4wd axles. Say it stays in better, doesn't leak past the seals on the ball.
John | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I wonder if "knuckle pudding " would work? Over at the Willy groups the guys mix 90 weight oil with grease half and half to put in the universal balls on the front 4wd axles. Say it stays in better, doesn't leak past the seals on the ball. Yep, that should work fine. That is what I did, but I used 120 weight gear oil and bearing grease. Mixed to self leveling consistency that I felt would still allow adequate lubrication to the top bearing.
| | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | What type of grease is it just general corn head grease | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A corn head grease is the correct consistency. John Deere sells it by the tube. People have posted other sources.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Press "Reply"
Use the second icon from the left (above the edit "window" - the icon is a globe with two chain-links under the globe.
Put the URL in the first box and then press "OK" Put the words/description in the next box and press "OK"
You can then edit the words/description, if you want to do so.
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 |
40 Chevy 1/2 ton
| | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | That sounds good. It will be a thick but self-leveling grease.
Fill it to the plug and then wait a while for the grease to level out. Then, top it up into the plug hole. This pipe plug is the fill plug on the top of the steering box correct?
1942 BK 1/2 Ton Pickup 1954 3800 1 Ton Pickup
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | . . . . This pipe plug is the fill plug on the top of the steering box correct? 1942? Yes, it is a/the pipe plug. Fill to just below below the base of the hole. Drive/steer the truck. Re-check the level and fill to just below the pipe hole. http://chevy.oldcarmanualproject.com/shop/1942/42csm0011.htm | | |
