2 members (Steveoreno, TPR57C),
106
Mod | | | Forums66 Topics128,186 Posts1,057,320 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 32 New Guy | | New Guy Joined: Aug 2013 Posts: 32 | I have a 1946 GMC/Chevy 1/2 Ton. I have original floor boards and an original cab. I purchased the truck in pieces so I have not seen how it goes together.
Question 1 -------------------------------------------------------------------------- There is a large rather square piece that clearly sets down on the floor like a tunnel or tranny cover. This piece fits nicely.
Next there is a more rectangular piece that goes on the lower portion of the fire wall. All bolt hole line up nicely.
These are the two main floor pieces. I'm not worried about all the little pedal stuff.
Each piece individually lines up nicely. You can clearly see each bolt hole.
Both piece nicely fit to each other when not in the truck.
My issue is that when in the truck the lower lip of the firewall piece is a little over an inch away from the front lip of the large main floor piece.
clearly they were meant to go together. I'm wondering if there is a rubber seal or a brace that I am missing to fill in this gab.
I will try to get pictures later today.
Question 2 -------------------------------------------------------------------------- How does the hood stay on? I feel I am missing a metal dowel that would run through the center of the two hood pieces. It looks like the cab has a place for a metal dowel to sit and then have some type of fastener over it.
I have no idea... I have not seen such a thing. I am just looking at what I have and making a guess as to how it could be fastened. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Send me an email and I'll send you some photos. The hood hinge interlocks. No center pin. Each end of the hood hinge sticks out about an inch and fits into the curved center piece at the front and a small bracket at the cab. The floor I don't know. The bottom overlaps the sloped firewall portion. [email protected] | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | Question 1. I have not ever seen a rubber seal or brace in a parts list but it would not hurt if you feel the need to make your own.
Question 2. You need a dowel pin.
If your truck came in pieces these are the least of your worries right now. | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Send me an email and I will send you picture's of the parts that you should have. The hood half's slide together in the middle not what people would call a hinge today but that's what it is, replacements are available from various vendors. Kirk AKA 41Chevy email [email protected]
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Kirk, The 1929 - 1954 Chevrolet MASTER PARTS and ACCESSORIES CATALOG calls it Top Hinge as well as the suppliers that sell the replacement.  Harold
Harold Is a restoration ever finished? | | | | | Joined: Aug 2013 Posts: 32 New Guy | | New Guy Joined: Aug 2013 Posts: 32 | Name is Gordon...
I am missing the bracket 8.058 and nut 8.064 I have the support 8.015 but I don't know how it goes on the hood.
As for the lest of my worries... not really. I'm only using the body of the original truck. Not having a 46 to look at makes these little things rather hard to figure out.
| | | | | Joined: Aug 2013 Posts: 32 New Guy | | New Guy Joined: Aug 2013 Posts: 32 | So I found the bracket on ebay. I still don't see how that hold the hood on. It seems there needs to be a roll pin in the hood and in that bracket. My top hinge is two hooked pieces attached to each side if the hood. These then slide together. One inside the other. http://gordonfrench.com/46/hood1.jpghttp://gordonfrench.com/46/hood2.jpgis the a tab broken off my top hing? both ends of my hinges line up flush when the hoods are slid inside each other. There isn't any type of tab on one of them. | | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | Your hinge is broken. The ends should stick under the small strap at the rear and into the hood ornament in the front. One half of the hinge should measure about two inches longer then the other and the same as from firewall to 1" into ornament.
You need a new hinge.
Joe | | | | | Joined: Aug 2013 Posts: 32 New Guy | | New Guy Joined: Aug 2013 Posts: 32 | thanks... that covers the hood issue.
The exploded cab view does not show the floor panels. I will get a picture tonight, to show this gap. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I don't know where you are in CO, however, I have a complete '47, first series, GMC truck you are welcome to come look at, Longmont- N of Denver.
| | | | | Joined: Aug 2013 Posts: 32 New Guy | | New Guy Joined: Aug 2013 Posts: 32 | I don't see how to send pm's on here.
| | | | | Joined: Feb 2008 Posts: 1,124 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,124 | Gordon One way to send a PM is to click on the user's name. Up will pop a short menu. One of the selections is for sending a PM.
| | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | I WAS WRONG!!! The two top hood hinge pieces "nest" together while the hood side panels use a pin to hold them to the top hood halves.
Be sure that the stamped/molded pins on the ends of the two hood hinge sections are still there, otherwise they will not rotate around the center as you raise the hood.
Jim Carter has some of these reproduction hinges.
My apologies.
Sorry for the miscommunication. | | | | | Joined: Aug 2013 Posts: 32 New Guy | | New Guy Joined: Aug 2013 Posts: 32 | We established my hood hinge is broken and missing the tabs or pns that go into the front brace and under the rear bracket.
I found a new hood hinge and a new rear bracket online. Is this Jim Cater a forum sponsor? | | | | | Joined: Aug 2013 Posts: 32 New Guy | | New Guy Joined: Aug 2013 Posts: 32 | So another member (ewwirth) was wonderful and sent me pictures of his floor with a tape measure in them.
His center main floor panel is 20" long to the top of the lip. Mine is 18.5" long to the top of the lip.
Apparently, there we different size opening in different years.
Thanks guys, I will be adding 1.5" to my floor panel this weekend.
Thank you so much for taking the time to send me all the pictures. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If you are anywhere near Pierce, there is a farm show there, Sat., several trucks and tractors will be there.
| | | | | Joined: Aug 2013 Posts: 32 New Guy | | New Guy Joined: Aug 2013 Posts: 32 | Hope the show was fun. I don't think I could get much farther from Pierce and still be in Colorado. I'm 65 miles east of Pueblo. | | |
