4 members (Otto Skorzeny, Gdads51, Opelika Tom, crenwelge), 75 guests, and 1 robot.
Topics128,062
Posts1,055,851
Members48,428
#98220 11/24/2006 11:22 PM
My turn signals just stop working yesterday. Before I start hunting down the cause how likely is it that it could be the "flasher" unit.
Tom
#98221 11/24/2006 11:30 PM
It is very likely if the front and rear lights just turn on and don't flash when you signal either direction.
#98222 11/24/2006 11:33 PM
It's possible. Very possible.
If you turn the blink on and get out and look at it, does it glow steadily?
If yes, then you need a new flasher relay.
Otherwise, I think you could have grounding or switch issues.
If all else fails, there's always Blinker fluid . grin grin grin
#98223 11/25/2006 12:16 AM
Hey Tom,first check your fuses.If they are good,you can jump out the flasher with a paper clip or cotter pin.If the lights go on then your flasher is bad.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#98224 11/25/2006 1:01 AM
I stand a chance of being corrected but I think that basically, a flasher is a bi-metal strip that makes and breaks contact as it heats up and cools down. That is why they sold heavy duty flashers for cars pulling trailers. Too many lights on a standard flasher and the think heated up and cooled so fast that it looked like the flasher was on speed. Although possible, I doubt the trouble is with the flasher.
#98225 11/26/2006 4:34 PM
You are right Greg_H. An overloaded flasher will flash rapidly.One that is open circuted will not flash at all.When you jump it out and the lights come on ; it will prove the circut good and the flasher bad.Check fuses first with a test light,jump flasher second,power at the bulbs with the flasher jumped third.
Wanted Good Woman:
#98226 11/26/2006 10:50 PM
Well after checking out the system it was the flasher and now all is well!
