| | | Forums66 Topics128,089 Posts1,056,353 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Well, I got the tie rod straightened out pretty good but I found that one of the tie rod ends had been hammered over pretty good, making the removal of the plug difficult, and re-install even worse. I considered replacing the tie rod ends - they did show some wear. I have the type of tie rod end pictured in the "42-48 Car / 42-46 Truck" shop manual, figure 43, page 3-19. I cannot find this style in any of my catalogs. I could probably clean the threads up with a tap (1" x 18), but the taps don't seem to be readily available. Can any one help?
BobS46
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I have a tie rod with the ends still on it. What do you need? Best to send me a PM. What I have is from a 46 pickup. | | | | | Joined: Sep 2002 Posts: 153 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 153 | I bought a new tie rod from Classic Performance Products. I bought two sets of the "modern" tie rod ends (I don't remember who I bought them from). I cut down the original tie rod and made a drag link. My set up required a 13/16" x 16 die and a 2" die holder. JTS Machinery and Supply. Die Holder (copy and paste): https://www.jtsmachine.com/jtswebshop/Taps_Dies/T215.asp#holderDies (copy and paste): https://www.jtsmachine.com/jtswebshop/Taps_Dies/T126.asp#2
1946 Chevy Half Ton ('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS) 1976 Margay Panther X, MC91B | | | | | Joined: Oct 2013 Posts: 2 New Guy | | New Guy Joined: Oct 2013 Posts: 2 | Bob,I also will be replacing my tie rod ends and drag bar shortly (after the holidays). What did you end up doing? Was it expensive? Thank you | | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Thanks to a fellow member of the forum, AChipmonk (sp?), I located some used tie rod ends. They did not seem to be otherwise available and one of mine was damaged beyond use.
My local shop did a very good job of pressin the rod out straight. Sorry that I can not be of more help.
BobS46
