9 members (Nhluvstruck, 32Fordpuchoptop, Bill Hanlon, DHedrick, Ponchogl, Southerntruck, Otto Skorzeny, 1955 1 Series, 1 invisible),
125
0
Mod | | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | So I saw a Le Mans going down the road the other day that said "OHC 6" on the fender. When I got home I looked it up. Apparently it was loosely based on the 230 chevy. Looks like a dandy re-power for one of our trucks???? | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | they are interesting engines, however had problems with oil pumps.Two versions low and high performance, ran pretty good. Guess they were not that dependable as they were only produced for three years i believe.Have a friend that had an original firebird with one in it, He took it out and replaced it with a 383 chevy.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | There is a PONY OHC 6 being built over on Inliners in the Blown & Injected forum. Quite a build.
Drew
| | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | I believe the problem was with oiling the cam followers and cam bearings, not the oil pump. The engine is based on the 230 but no parts swap over.
Joe | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I had read they had some problems at first with the belt that drives the cam. Only thing the heads are not interchangeable with a regular 230/250 block.....
John | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I have a 66' 230 if anyone is looking. Contact me privately. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | The only problem I could really see is, well they were only produced for 4 years....But it would surely be unusual. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | The engines were not made in any great quantity because they were not popular and cost more than the base V8 engine did. Don't confuse problems with cost numbers. These were perfectly good engines with a LOT of advanced engineering for the time. But expensive to manufacture in low volume. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I believe those and the Vega are similar in head design and a brain child of John DeLorean.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 | I do believe these engines were 4.1L, or approximately 250 cubic inches, not 230. The high perf model had a split exhaust and a quadrajet, they were pretty neat.
1950 4100 - unrestored and driven weekly for almost no reason at all.
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | I do believe these engines were 4.1L, or approximately 250 cubic inches, not 230. The high perf model had a split exhaust and a quadrajet, they were pretty neat. I'm too lazy to convert to metric, but the 1966 and 1967 were 230 CID, the 1968 and 1969 250 CID. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 | I stand corrected, I see now that the early ones were 230ci, or 3.8L and the later ones were 250ci, or 4.1L. The weakest one was rated at 165hp and the hottest one was rated at 230hp. Impressive.
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I'm with CarbKing and here we use Cubic Inches. The Europeons and others can have the Metric system. The only advantage I've ever seen is that it makes Canadian gas look cheap until you pay for it. | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Moneypit - at least once a week someone calls and asks me for a carburetor or repair kit for a n.n 1935 Packard, 1922 Dodge, etc., etc., etc. Where in the world are they finding these metric listings??? Of course, I never have what they think they are looking for.  Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 | I'm not sure of the reason why, but Pontiac badged the cars with these engines in them with a metric displacement. They were listed as either a 3.8 or a 4.1 litre, said it right on the hood or a fender emblem.
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Must have been the early Communist Invasion prior to Jimmy Carter's failed attempt at converting us away from The American System like Jesus wrote in the Bible. I would probably go for metric time. All those twelves and twenty-fours and sixties give me a headache.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | the one I saw just said "OHC 6" and the 6 was red. It was on a LeMans, (or did I say that already?) As an aside, apparently we (the U.S.) have been officially metric since 1893 (the mendenhall act or something)
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | All of the Japanese cars I have worked on had US dimensions on there wheel and master cylinders. Why is that?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 | That's a good question - I have also noticed that in the past. I figure it has something to do with an industry standard regarding brake system hydraulics.
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | For those too young to remember there was a big push back in the 70's to shove the US over to the Metric ssytem. A lot of that shove came from our own homegrown intellectuals (re: Obama types) and from the Europeons who haven't been able to get much right for close to two centuries. Well some of it did stick but in large part we still have 12" to a foot, 16 oz in a pound and 32 oz in a quart. Remember boys and girls..nobody has come close to our level of success as a society or industrial giant and those who thought they were (Japan, Germany) got clobbered but good. And we did it the wrong way according to the brainiacs. So yes, darn straight I like our system and I'm not about to apologize for it.
Now let's get back to the Pontiac question if there are any left. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | didn't anyone see the part about the US has officially been metric since 1893? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | take it to the Spoon Dave, no politics in the forums Bill | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Yeah, your right Bill but it's history man. | | |
