BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
1 members (Movingeric),
487
robot. | Key: Admin,
Mod | | Forums66 Topics126,777 Posts1,039,270 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Feb 2001 Posts: 95 'Bolter | 'Bolter Joined: Feb 2001 Posts: 95 | Can anyone tell me or have photos of the original tail light wiring routing and what was used by GM to hold the wire to the frame? Also, where does the speedometer cable route? Seems these would follow the same path down the firewall??
Thanks | | | | Joined: Sep 2006 Posts: 3,597 'Bolter | 'Bolter Joined: Sep 2006 Posts: 3,597 | The 1954 factory Assembly Manual is going to be your best guide for this. It is available from many vendors as a reprint. I an not sure if there is a web copy. It has the detail you seek usually over a few pages. | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | Shop Shark Joined: Jan 2013 Posts: 1,384 | On this '48 the wires are held to the frame by rectangular spring clips. The clip has 2 tabs that push through a hole in the frame and hold it in place. The face of the clip has u shaped clip to hold the wire. Haven't looked for replacements but it is on the list | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | Shop Shark Joined: Jan 2013 Posts: 1,384 | Those wire hangers are different. Look like they attach with nut and bolt.
I'll see if I can get a picture of one alone. Can't show them on the frame, not back from powder coat. | | | | Joined: Feb 2001 Posts: 95 'Bolter | 'Bolter Joined: Feb 2001 Posts: 95 | I have the 1954 factory Assembly Manual but could not find the info I'm looking for in it.
One of the issues is I can't figure out if the wires go above the master cyl bracket or through the master cyl bracket. | | |
