Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (2-Ton, Peggy M, Youngin' Tut 59, Jon G), 36 guests, and 7 robots.
Topics128,010
Posts1,055,303
Members48,419
#980513 10/22/2013 9:47 PM
I have seen the engine in the 55 1st series 3100 blue and some gray. Which is right?
markst47 #980533 10/22/2013 10:52 PM
markst47 #980619 10/23/2013 3:14 AM
My 1st series 55 261 is GREEN! FYI
1946 1/2-Ton Chevy
markst47 #980942 10/24/2013 3:18 AM
JiMerit Boltr#43,
A green Jobmaster 261 on a 1955 truck would be quite natural (yellow was also supposedly used that year on a 261).
In 1955, a Loadmaster 235 would have been green (but would not have been on a 3100).
markst47 #981321 10/25/2013 3:30 PM
I have an unusual situation... as would be my norm smile
Concerning my '59 3200 project, I have two 261's.
The first was rusty all over so I was starting from scratch. I rebuilt it and researched paint color for it.
I found online, yellow or green was the correct color.
I bought the Detroit Diesel Alpine Green paint and finished it up. It looks great!
OK now for the twist. A '58 1/2 ton truck that I bought for parts from a work buddy had a 261 in it. His grandfather bought the truck new from a local dealership and the engine has never been rebuilt... until I rebuilt it. This engine was like new! Everything was standard size and there wasn't even a ridge in the cylinders... all I had to do was hone them.
This engine was definitely Blue... after the rebuild, I repainted it the same, Chevy Engine Blue.
First off, I would never have expected a 261 to be in that truck. second, the engine color isn't what the net says... oh and one other thing... the "stamping" code on the machined pad near the distributor? There isn't one... the pad is clean.
I don't mean to hi-jack this thread, I just thought I'd state something different concerning the topic. Maybe engine color wasn't a spec adhered to? ohwell
Thoughts?
markst47 #981355 10/25/2013 4:29 PM
Jerry, as you wouldn't expect it in a 1/2T, maybe that 261 was a special order? the lack of a stamped code throws all else out the window
markst47 #981363 10/25/2013 4:57 PM
Thanks for the comment, Bill.
At least I have casting date codes which are correct for the year (as casting codes go).
The color... Blue looks great too and I'm convinced it is correct to that engine.
The end result, it runs and looks great!
My '59 doesn't know it yet, but it's going to be happy when it's reassembled.
markst47 #981410 10/25/2013 10:31 PM
That blue 261 might be a later replacement engine - it would have been painted whatever color suited the installer and/or the owner. Chevy blue was a common color found in engine shops.
markst47 #994829 12/26/2013 6:40 AM
I agree with tclederman, It is likely a replacement engine.
especially if the stamping pad is still untouched. The dealerships
that I worked at just painted them with what was most common, Blue or Grey for most sixes.
I have two 261 engines that were green from new. It is easy today to also get into a debate about grey small blocks in trucks.
Everyone thinks they should be orange like in the cars.
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
