| | | Forums66 Topics128,175 Posts1,057,056 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 32 | anybody know who makes wood for 36 cabs. I need some door post pieces for a high cab. [email protected] or call 601-898-4718. Thanks Allen | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | K.C. Wood Mfg. is in Va. but according to their web page they are not excepting any orders right now. They are not cheap but I understand they do quality work. You may want to try them later. http://www.chevywood.com/...I have read many accounts where the wood has been replaced with metal tubing of some sort. Unless your doing a 100% resto you may want to look into that? | | | | | Joined: Nov 2012 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 32 | The steel is probably the best solution and I am not trying to make it totally original any way. Thanks for the info. Allen | | | | | Joined: Jan 2012 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 32 | You might try Classic Wood Manufacturing in Greensboro N.C. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | There are some kits that have the steel framing pre-made to fit right in as replacement for the wood. I don't know who makes it off hand but a google search should help. | | |
