| | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 23 New Guy | | New Guy Joined: Oct 2013 Posts: 23 | building a 1953 chevy pickup, has small block chevy, 350 tranny, and a late model rear end with drum brakes. all of the original components of the emergency brakes were removed before I got the truck and I am not real concerned with replacing to original. Any suggestions as far a manufactures of aftermarket components for emergency brakes in this scenario would be appreciated. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...IF you have bucket seats AND you kept your cross bar that the E-brake cables hook to, may want to try what I did. I used a brake handle that is in a lot of cars between the bucket seats. (mine came from a Colt but most any will work) Once I had it bolted in the floor I ran a cable from the rear cross member to the handle. Works like a charm. http://i140.photobucket.com/albums/r19/LutherParris/52Panel/EmergencyBrake001.jpgIf you want a pic of the handle between the seats I can take one. Hope this gives you some good ideas. | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | As far as after-market, you can look at Lokar, I believe they probably have something that will work, but you will pay for it. Not sure why they seem to really be pricey--might just be my budget!! (Well, quality probably has something to do with it too...) Here is a linky to their e-brake webpage: http://lokar.com/product-pgs/ebrake-cables-conn-cables/ebrake-cable-main.htmlIt might be easier to just download their catalog and look at it in Acrobat since thier website has got a lot of stuff going on when you just want to look at thier products (my opinion). In the catalog they have Chevy truck (AD) sp3ecific cables, FWIW. I am planning to use my original pull lever under the dash (Task Force truck)and fab to F*rd 8.8 rear cables. Probably use the orginal lever in the middle of the frame and hook cab pull lever to it with original Chevy cable, then hook 8.8 cables to it. (Exploder rear end has disc brakes with the little internal brake shoes for the parking brakes.)
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | The Lokar universal kit is very good and will probably be your best bet, but you do need most of the original parts inside the drum/shoes to hook it to. You might need to go fishing at a junkyard if you're missing parts in there. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | i have a 49 chev with a 350/350 and a 12 bolt......i used a lokar trans mounted e brake lever and their cables....could not have been simpler......dave
ps...it may seem a little pricey...but i'll take simplicity and quality any day......dave
1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | You could always do a pinion brake. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | You could always do a pinion brake. Depending on your location, some vehicle equipment regulations don't allow a pinion brake as an acceptable emergency brake. | | |
