4 members (Otto Skorzeny, MickeyP, Wally / Montana, Bill Hanlon), 138 guests, and 1 robot.
Topics128,052
Posts1,055,729
#979519 10/18/2013 11:50 AM
Searching for diff gasket for 59 16,000 lb rear axle. found # 3762399 have 10 anyone needing one? I needed 3711464 Cdan
1959 Chevy Viking 60 & Wrecker
See I told you it would work. That Beaver Cleaver will do anything.....
3B Offline
Hy cdandelivery, a little more info is needed to help you in your quest, the o.e.m. p/n you quoted did not crossover at the Napa site. Is the rear axle a single speed or a two speed, do you want the diff installation gasket or the cover gasket, and finally how many holes are in the gasket?
Eaton and Meritor hasn't used a gasket on the 3rd member for many years. They use RTV silicone. We couldn't afford to use gaskets on our trucks anymore because the gaskets always weep and we would be written up for oil leaks. Use some Permatex RTV and you can forget about it. If you are worried about originality, just scrap the excess RTV off with a razor blade and no one can tell the difference.
3b its for A 16,000 axle 2 speed.Napa has no cross for the gaskets. I found a few paper 3762399 GM part.and finally a few cork 3711464's all are in good shape. the 3762399 is bigger than my housing leading me 2 believe its for a 70/80 series but if they are any who need... let me know
3B Offline
Hy cdandelivery, according to my research, a 59 60 series would have an Eaton 16600, the diff gasket is Fel-Pro p/n RDS 6335-1 $7.74 USD at RockAuto, the cover gasket is p/n RDS 5817, (no parts found at RockAuto), hope that helps.
Hi,and WELCOME,cdandelivery! I tried to click-on your "link",but it doesn't work, The moderators suggest that you use a photo/video sharing site,examples being "Webshots",and "Photobucket".com,to name a couple. If you link directly to "Stovebolt.com",it causes issues. Hope to see some pic's,soon. Thanks!!
Mo' Tater
