3 members (GMCJammer51, Jay R, TUTS 59), 91 guests, and 2 robots.
Topics128,186
Posts1,057,324
Members48,469
#979725 10/19/2013 11:52 AM
I have a 41 chevy and looked at a 46 grill yesterday. The 46 grill had something different than mine, on the top of the bottom section there is a small chrome trim piece that goes over the top of the entire lower grill, is this standard for 46? Should my 41 also have this piece? I could not see how it was attached or I would have taken it off. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
homer52 #979754 10/19/2013 4:25 PM
half-tonne '46 is 2-piece (upper + lower, nothing else, like my boyfriend's dentures)
could yours be ex-military?
homer52 #979802 10/19/2013 9:04 PM
My '46 grille has the bead across the top of the lower grille. Don't know what a '41 is supposed to look like.
Grease magnet
homer52 #979824 10/19/2013 11:47 PM
Do you know if that bead is easily removed? I can take this one off of the 46 here if it will fit on the 41. In case you are wondering I'm visiting in Pa. and there is a 46 here on the farm, my 41 grill is at the chrome shop right now so I can't look at it. Dave
1941 Chevy
homer52 #980038 10/21/2013 1:21 AM
I've seen quite a few 41-46 trucks in my days, and only seen one style grill for those years, either chrome or painted.
The trim pieces at the top of the lower grill were stainless for the chrome grills and painted steel for the painted grills in my experience. There are twist "tee" connectors that hold that trim in place similar to the connectors for the hood side trim on the 41-46. They are easily removed if you have access to the back of the grill. If you try to remove the trim without untwisting the tee connectors you will likely damage the trim.
The after market grills for the 41-46 trucks have that trim spot welded to the upper portion of the lower grill. The after market grills can also be easily identified by the bottom of the lower grill, which is also spot welded on, as opposed to the original one piece stamped grill.
