7 members (Leo, Goach2, UtahYork, klhansen, JoeDude, pauld, Wayne67vert),
129
Mod | | | Forums66 Topics128,185 Posts1,057,290 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I have a 41 chevy and looked at a 46 grill yesterday. The 46 grill had something different than mine, on the top of the bottom section there is a small chrome trim piece that goes over the top of the entire lower grill, is this standard for 46? Should my 41 also have this piece? I could not see how it was attached or I would have taken it off. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | half-tonne '46 is 2-piece (upper + lower, nothing else, like my boyfriend's dentures)
could yours be ex-military? | | | | | Joined: Jul 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 34 | My '46 grille has the bead across the top of the lower grille. Don't know what a '41 is supposed to look like.
Grease magnet
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Do you know if that bead is easily removed? I can take this one off of the 46 here if it will fit on the 41. In case you are wondering I'm visiting in Pa. and there is a 46 here on the farm, my 41 grill is at the chrome shop right now so I can't look at it. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | I've seen quite a few 41-46 trucks in my days, and only seen one style grill for those years, either chrome or painted. The trim pieces at the top of the lower grill were stainless for the chrome grills and painted steel for the painted grills in my experience. There are twist "tee" connectors that hold that trim in place similar to the connectors for the hood side trim on the 41-46. They are easily removed if you have access to the back of the grill. If you try to remove the trim without untwisting the tee connectors you will likely damage the trim. The after market grills for the 41-46 trucks have that trim spot welded to the upper portion of the lower grill. The after market grills can also be easily identified by the bottom of the lower grill, which is also spot welded on, as opposed to the original one piece stamped grill. | | |
