2 members (tesa, Guitplayer),
110
Mod | | | Forums66 Topics128,186 Posts1,057,302 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | I am getting ready to mount my rear fenders on my '52 GMC 1/2 ton soon and am curious to know whether the rubber gasket offered by Jim Carter or the thin roofing felt one offered by Classic is correct for an authentic restoration.
| | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | I purchased the z shaped gasket / felt from Classic and have to say it is so thin, it won't make a difference. I am thinking about making my own out of a piece of rubber. Not that the two parts should move much but the rubber will be a better isolator than the felt. I presume the felt would be in keeping with an authentic restoration, but that would be a reasonable thing to change in my opinion. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The original anti-squeak was felt paper, but it was thicker than the 10# roofing paper the vendors are selling. Use some 30# roofing paper if you want it to be like the original one. Same stuff used for the front fenders. No need to buy any of the anti-squeak a yard of paper will make all you need for an AD restoration.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | Thanks Denny. I already did as you suggested for the anti-squeak between the inner and outer fenders and cab so I already have a roll. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I agree, the vendor anti-squeak is way too thin. Same for the transmission floor panel. But, the vendor gaskets make a good template to cut your own from heavier material. I am not at that point yet, but am either going with 30# roofing paper, or will use a heavy "gasket" material available at most FLAPS. Just not sure the gasket material rolls are large enough for every piece of anti-squeak needed. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | No sense in throwing away your coin on gasket material David, it's way more expensive then that roll of 30# roofing paper and won't function any better. But, if you insist, try McMaster Carr, you can buy any length you need there. I would actually like to find some treated felt paper that was heavier then the 30# but I've been looking for 6 or 7 years without any luck, apparently no one makes it. The original gasket for the trans cover was a full sheet formed to fit the contour under the trans cover, not 1" wide strips just at the edges. It was heavier than the 30# paper though. I had some pictures posted way back when of how I vacuum formed a new one. They were posted on Webshots when it was the only choice but we all know what happened to that. The original pictures are on my old confuser that crapped out on me last spring, no back up either DUH. Denny Graham Sandwich, IL
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I wanted a thicker than 30# felt gasket in one of my applications so I doubled it up and 'glued' it together with a thin coat of plastic (not tar) roofing adhesive then made the gasket out of that... (yes, I made sure it won't drip/ooze out)
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I agree with you Denny. I was just thinking of gasket material when I needed something thicker than the 30# felt. For the trans floor cover, I used 1/4" thick by 1" wide or so foam door weather strip. I may switch it to 1/4" neoprene (a bit more durable). I want that sucker to seal. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Okey dokey fellers, took some work but here are those pictures of my reproduction of the original 4-speed transmission cover gasket vacuum formed from 30# felt paper. http://www.pbase.com/dennygraham/transmission_cover Denny Graham Sandwich, IL
| | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | I have to say that is brilliant. Vacuum bag molded the felt paper better than I could imagine. Your attention to detail and precision is enviable. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Come on Bob, you're embarrassing me. I'm just an old farm boy from the country. Point is that the cover did originally have a sheet gasket on this truck, not just strips. The original one was made from a heavy paper, my guess would be about 50# felt paper that was die cut to the shape. And it was formed to the contours of the cover. That's why I'm 98% positive it came from the factory that way. I can't envision the local mechanic from a small town in south western Iowa making up a gasket like that. I'd be interested to know if Brad has run across remnants ofthis type of gasket on any of the dozens that he's parted out. Denny Graham Sandwich, IL
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | What was on my 52panel rear fenders is just what Denny is talking about. I think I saved a piece of the original but no telling where I put it for "safe" keeping. I used something else on the rebuild but I've also use the #30 roofing felt a many of times. It also works good on gas tank straps. | | | | | Joined: Dec 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 113 | Denny, what adhesive did you use for the trans cover gasket? Wish I had read this post a few days ago because I just got all those gaskets n he mail. I also bought a roll of heat shielding for the trans cover because I knew there was evidence of more than just the inch wide gaskets but not enough to know what was there so I figured that was better than nothing. Guess they will be good templates though. Just painted the old truck and getting ready to put it all back together. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | There was evidence of a tar like something that had the original one stuck to the bottom of the cover. I haven't glued mine down yet because some day I'm planning to spend a complete body off the frame winter. That is, if I ever get finished getting ready in the new barn/auto shop/spray booth/machine shop/wood working shop. What ever you use, it needs to seal the opening so it doesn't form a pocket between the gasket and the cover. I think this was GM's way to add a little sound deadener to the floor boards at the same time sealing up the trans cover.
Denny Graham
