1 members (78buckshot),
64
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | After 2nd shake down drive everything is rosie, now some brown seapage from deck on driver's side! The thing runs fine but this is not good, any ideas??? Re-torque? Oil and water look normal, no smoke or leaks.
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I would try a re-torque after it's fully warmed up. What was done to the deck and head surface before final assembly ? What brand head set ?
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Head was re-surfaced, deck was checked with a straight edge. Got the 'Best' brand head set from Patrick's. You are saying to torque hot or after she's been warmed up? The thing has been on the road once after breaking in a new cam, ran over 20 min.first in the shop.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | What type of gasket? Copper? Composition? I think Best offers more an one type. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Head gasket was not copper, believe was their composition type. | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Do not panic. You state it runs fine. Retorque at operating temp. Clean and watch.I built engines for 23 years and it is not uncommon for a stain to develope on the block. Cleaning solvents/lubrication will leach out of HOT screw threads (head bolt holes) and cause a block stain. I have watch the head bolts bubble (boil) fluids. My .02
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | When you installed the cylinder head bolts did you oil them? By oiling the threads and then torquing you are putting much higher torque on them.... well, you are still applying the same torque but the amount of bolt stress is much higher.
Page 6-2 'Installation' para 2. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I believe part of the procedure in the shop manual for head installation is a re-torque after the engine is warm. That is for a 216/235 but a 261 wouldn't be that different. WhenI did mine some of the bolts moved at lower values.
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | The only post-install procedure after warm up is adjust the valves.
You can always re-torque the bolts... but like I said, the initial assembly was to oil the threads. Oiling the threads allows the bolt to stretch more and that is what creates the torque. Un-oiled threads most of the torque is from friction of the metal-metal contact. You can get 30% more torque from oiled threads than unoiled. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | When you re-torque the head bolts, loosen each bolt one at a time and torque to specs. If you try to set the torque on a tight bolt, you won't get proper torque. The wrench needs to be in motion as you reach the desired torque reading.
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Had the same weeping problem on a 262 Ford six after running the rebuilt engine for a half hour. Retorqueing the head took care of it.
1939 Chevrolet Stake Truck
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Thanks for all the great input, Bolters are the best. Jim | | |
