0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#978913 10/15/2013 10:37 PM
I was not getting much oil to the rockers on my 235 so I
so I "T'd" at the filter and went direct to the side oil plug. The problem is that I now have oil squirting like a gusher out of the front half rockers and next to nothing out of the rear rocker set. What's going on? I also changed the tar black oil and put in a new filter and oil and the oil turned black almost immediately. Should I worry?
The front shaft is most likely upside down. If the supply holes are put on the top it can cause squirting. They should go down. There could be other scenarios but I would start there.
My Blog
Check for sludge buildup inside the rocker shafts while you have them off to check hole orientation. That might be why you didn't have adequate oil to the rockers in the first place. You can knock out the end plugs to ease the cleaning process. They are like really small freeze plugs and can be driven back into place after cleaning the shafts.
Thanks, I'll check that out today.
A Rifle Bore Brush works wonders on the rocker shafts for cleaning!
steve sr.
Yes the rocker shaft had the holes facing up! I can blame my son at least, he was the one that put the assembly on. But when I got it corrected I found a bent push rod. Will a rod from the 216 I took out substitute OK?
