| | | Forums66 Topics128,022 Posts1,055,361 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 36 | I was not getting much oil to the rockers on my 235 so I so I "T'd" at the filter and went direct to the side oil plug. The problem is that I now have oil squirting like a gusher out of the front half rockers and next to nothing out of the rear rocker set. What's going on? I also changed the tar black oil and put in a new filter and oil and the oil turned black almost immediately. Should I worry? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The front shaft is most likely upside down. If the supply holes are put on the top it can cause squirting. They should go down. There could be other scenarios but I would start there.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Check for sludge buildup inside the rocker shafts while you have them off to check hole orientation. That might be why you didn't have adequate oil to the rockers in the first place. You can knock out the end plugs to ease the cleaning process. They are like really small freeze plugs and can be driven back into place after cleaning the shafts.
| | | | | Joined: Oct 2011 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 36 | Thanks, I'll check that out today. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | A Rifle Bore Brush works wonders on the rocker shafts for cleaning! steve sr. | | | | | Joined: Oct 2011 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 36 | Yes the rocker shaft had the holes facing up! I can blame my son at least, he was the one that put the assembly on. But when I got it corrected I found a bent push rod. Will a rod from the 216 I took out substitute OK? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
