| | | Forums66 Topics128,005 Posts1,055,261 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 9 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 9 | I have a '66 C10, 250 six with a 4 speed tranny. I have a 283 w/3spd OD to put in the truck. I have heard that it is possible to add the OD unit to the 4speed tranny. Have any of you guys done this? or have any information about doing this? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I don't think it is possible to put the Borg-Warner O-drive behind the 4 speed. There is an aftermarket O-drive that can be put on. It is very expensive. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not - if you have both it should be pretty easy to judge whether the OD tail unit off the 3 speed would bolt up to the back of the 4 speed
Bill | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Install the V-8 with the OD trans and you will be happy. You will need to modify the drive shaft and work out some shift linkage. Fred
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | | | | | | Joined: Jun 2012 Posts: 197 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 197 | The old overdrives are for the Saginaw 4 speed, not the Muncie SM420 truck 4 speed with the granny first gear. If you have a Saginaw 3 speed with OD and the trans in your truck is a Saginaw you should be able to swap IIRC. (some OD units are for the little Muncie SM318 three speeds)
FWIW there is something called a Ranger Torque Splitter OD that goes in front of a manual trans you can get for about $1,400 new. Gives you another shifter, and you can split gears with it.
Some of my crap: 1963 C-30 flatbed dually 292/SM420 1965 C-10 LWB fleet 250/column shift 3 speed 1965 C-30 9' stepside 250/SM420/4.10 gears (my DD) Website I made for my crap: http://www.66submarine.com | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | If you have a late model saginaw 3sp/with o/d,(with syncronized first gear, 7 bolt side cover) it can be mated to a saginaw 4sp car transmission. However there are some modifications that need to be made to it, unless you are familiar with transmission assembly you would be better off going with a t5 5 speed if you want overdrive.
Tommy 59 apache 1/2t 261 short stepside | | |
