1 members (CuzzFuzz), 228 guests, and 6 robots.
Topics128,101
Posts1,056,181
Members48,436
Page 103 of 177 1 2 … 101 102 103 104 105 … 176 177
Greased everything that could be greased. Tightened some nuts and bolts I found loose. Reset idle and reset the TPS. Bled the calipers again. Checked to see if the VSS was working. Tightened up the exhaust. Measured for a push bar.
Made a kick panel for the passenger side. Installed it.
popped in a new voltage regulator and new 12v headlights, drove over to norfolk to DOUMAR'S..it's a drive-in restaurant like sonic, but this one has been in norfolk since the 30s.. the trip to doumar's has been my personal goal for the truck when i bought it 6 months ago; i was to make the trip as soon as i got it road-ready. made the first run today and when i get there, they're closed hahah. not giving up, try again next weekend or the weekend after that
Started installing the electric wiper motor.
Took my 56 shortbox for its first long ride since starting on it a little over two years ago. Ran great! Can't wait to get the box on it before the snow flies.
1956 Chevy 3100 Stepside Shortbox
More pix on Photobucket
Took the '46 on a bit of a shake down run today after new rebuilt head and cam job. She ran great, no probs now just putting this puzzle back together. I've had this pickup since late 70s, on 2nd motor, 4th trans and third rear end. All is well.
1946 1/2-Ton Chevy
How about some pics?
~Jim
Good looking stuff!!!
~Jim
Installed the new fuel gauge. Jury is out on why it reads empty. More diagnosing when I have time. Finally got to my driver front bumper bracket. It had to be cut short to fit in front of the steering box. Only one bolt hole made it. I made enough mounting bracket way back when so that I could add a plate to the bumper bracket then drop a hole below the lonely hole that was left. Solid mounting, now. Installed the drivers side threshold plate with rubber. Need to re-clock the wipers.
Picked up a new oil sender from the Chevy dealer. The original (either came with the crate engine or was an after market sender I bought), always showed 25-30 lbs which is low for a 350 cid. My Yukon has always showed in the +70's. With the new sender my Oil pressure shows 75 lbs. Everything's copacetic.
~Jim
I promise to get some pics out here in the next day or so. smile The truck is at a welding shop today to have some frame issues fixed and the overload brackets straightened out before I drop the box on her.
Got my wiper linkage sorted out. Built the pushbar.
Just got in the new Euro gauges for the retro good
humor truck.I like the white face with the black letters.To add bling I`ll chrome the other items on
the dashboard by end of the year.Already have the
USA 1 radio cassette stereo.
[IMG]http://i1305.photobucket.com/albums/s554/icecreamman55/007_zps42284fbc.jpg[/IMG]
That is nice...I remember those trucks like it was yesterday
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
More work done on the push bar.
V
V Offline
Actually didn't do much to my 49 3100 except to take it out and enjoy it on a nice fall evening cruise grin
It's still mostly stock and based on how it sounded, felt and ran, it's happy spot is around 45 mph. I'm still getting used to it and it me. It's been moved to the 1st spot out of the shop, meaning it's 1st choice for cruising now. It doesn't hurt that the heat & electrics work good now as most cruises will be dusk to dark and on the chilly side.
It needs alot done but I'm going to enjoy it now for awhile grin
Dave
Mounted horn, moved gauges to my custom cluster, installed a 12v power port, had to put a little lift in the front springs, blew out all the desert sand and mud that has been falling in the back, added a little lift to the front coils and tested the pushbar. Doing more today after I pick my kid up from school. She wants me to pick her up in the ol' Suburban!
Installed a new drivers latch. Crappy aftermarket but better than the worn originals. Installed new outer turn down handles. Wired up the horn. LOUD!! Installed the temporary middle seat.
I got a GOOD S-6 Unity safetylight off fx+bay with the correct mounying bracket. POR the pass. door.
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
Went to Monroe swap meet and got a 55-57 GMC Hood ornament # 2333755, which depends on the source is original to 57 or 61
http://www.1955gmc.com/1955-59gmcliterature/HoodBird.html
I'm So HAPPY! yahoo
just need to fix and rechrome!
GMC: Get More Cash...
1958 GMC
My Webshots photos
Well I did the last work yesterday (keeping the Sabbath today!) but here's my build thread if you'd care t o look: http://www.killbillet.com/showthread.php?38526-50-3800-flat-bed-dually
Robert French MY3800FIRETRUCK
....now, if only I can get my head straightened up smile
Thanks for sharing. Your sure making some headway and nice work.
Got my '40 Special Deluxe and' 47 F**d winterized and put away for the winter.
Not a happy camper! Spent the weekend trying to repair & replace parts damaged by battery acid! It was charging but for some reason spit acid all over the engine compartment. It messed up my shiny new Air Gap intake, valve cover, sparkplug wires & starter!!
Robert C.
I'm a Genius in the making.
1950 3600
Hung doors to check fit (both needed extensive rework...other treads out there covering that topic) before final prep for paint. Doors fit ok except for slight panel to door flushing out issues (not bad enough for me to correct. Main problem is I notice the passenger door bottom is too far from rocker panel at rear. Something is bent and I am too far along to fix at this point. Don't think the door seal is going to contact the rocker...crud! Wondering if it was like that from day one. This is the side of the truck that I had severe door fitment issues (again, see other threads).
Installed more insulation and more wood floor.
Y
Y Offline
53 Burb. Finished sanding/stripping rear fender inner panels, plan to spray them with por-15 this week. Started cleaning up rear roof/qtr seams, right side rusted through. Made up patch panel for that and got it welded in, left side will clean up with sandblasting. Got to get a lot done before the good weather goes away!!!
Thanks!
Finished the plywood "pads" for the center seat.
ordered some bed parts.
Checked fluids, checked lights, loaded tools and stuff. Time to hit the road!!
Fixed the speedo head and unfroze the throttle cable on my 54 3100.
Love the classics!
1954 3100
1965 Mustang vert
Went over to the garage I store the 37 and fired it up,it looks like its battery time as I had to go back home and get the battery charger. It only sat a month and did not have enough to start it,battery is about 5 years old so I will get one next spring.
added some bigger castor wedges to the '40.
Finally swapped out the 5.14 ring & pinion gears for a 4.10 today. Going to fill her up with oil and try it out soon.
Large & In-Charge
1949 3800 1 ton' 5 window' 216
Started reassembling the hood for my '52 restoration. Welded the hood braces back in (after fitting neoprene between brace and skin) and bolted the hood halves together. Welded up stress cracked metal and will start with skim coat of plastic filler soon.
second to last primer coat on door interiors done. Just need to final sand cab/doors interior to be ready for interior paint.
I've been doing a few little upgrades to the truck since I got the slide on camper, pics and description over on this site;
http://www.nomadicista.org/viewtopic.php?f=4&t=1153&p=19731#p19731
Replaced generator and repaired turnsignals.
What's ya drivin'junkyard?
~Jim
