| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | I've finally figured something out, I have considerable play in the passenger side differential side gear. It can move up and down (from the spider to the axle) at least 1/32", and it also wiggles sideways. The other side gear has zero play. Now the questions: -is this bad? (my guess is yes) -can this be fixed with a sleeve / do I need a new diff? I'm pretty out of my comfort zone here, I don't really know what's normal. Once I know what it's supposed to be I could maybe fix it? Or find a replacement?
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | thank you. that's a great improvement over the shop manual. but mine does not use thrust washers, at least not according to the manual. and still nothing about side gear play. I just don't know whether I have perfectly normal backlash in all directions, or a worn sidegear, carrier, spider? And I really don't want to tear it apart if there's nothing wrong with it | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Thrust washers are optional (as required) on the spider gears. The manual for the HO-33 gives a max. freeplay figure. | | |
