2 members (qside, 78buckshot), 76 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#978105 10/12/2013 5:32 AM
I've finally figured something out, I have considerable play in the passenger side differential side gear. It can move up and down (from the spider to the axle) at least 1/32", and it also wiggles sideways.
The other side gear has zero play.
Now the questions:
-is this bad? (my guess is yes)
-can this be fixed with a sleeve / do I need a new diff?
I'm pretty out of my comfort zone here, I don't really know what's normal. Once I know what it's supposed to be I could maybe fix it? Or find a replacement?
I LOVE MY TRUCK
1959 Chevrolet Apache 38 Panel Truck in the Gallery
thank you. that's a great improvement over the shop manual. but mine does not use thrust washers, at least not according to the manual. and still nothing about side gear play. I just don't know whether I have perfectly normal backlash in all directions, or a worn sidegear, carrier, spider? And I really don't want to tear it apart if there's nothing wrong with it
I LOVE MY TRUCK
Thrust washers are optional (as required) on the spider gears. The manual for the HO-33 gives a max. freeplay figure.
