Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (cmayna, Hawkman, baldeagle), 55 guests, and 2 robots.
Topics128,006
Posts1,055,268
Members48,418
#978082 10/12/2013 3:19 AM
I have a '66 C10, 250 six with a 4 speed tranny.
I have a 283 w/3spd OD to put in the truck.
I have heard that it is possible to add the OD unit to the 4speed tranny.
Have any of you guys done this? or have any information about doing this?
Riding in the Passing Lane
I don't think it is possible to put the Borg-Warner O-drive behind the 4 speed. There is an aftermarket O-drive that can be put on. It is very expensive.
1972 Chevy c10 Cheyenne Super
not - if you have both it should be pretty easy to judge whether the OD tail unit off the 3 speed would bolt up to the back of the 4 speed
Install the V-8 with the OD trans and you will be happy. You will need to modify the drive shaft and work out some shift linkage.
Fred
700r4
The old overdrives are for the Saginaw 4 speed, not the Muncie SM420 truck 4 speed with the granny first gear. If you have a Saginaw 3 speed with OD and the trans in your truck is a Saginaw you should be able to swap IIRC. (some OD units are for the little Muncie SM318 three speeds)
FWIW there is something called a Ranger Torque Splitter OD that goes in front of a manual trans you can get for about $1,400 new. Gives you another shifter, and you can split gears with it.
Some of my crap:
1963 C-30 flatbed dually 292/SM420
1965 C-10 LWB fleet 250/column shift 3 speed
1965 C-30 9' stepside 250/SM420/4.10 gears (my DD)
Website I made for my crap:
http://www.66submarine.com
If you have a late model saginaw 3sp/with o/d,(with syncronized first gear, 7 bolt side cover) it can be mated to a saginaw 4sp car transmission. However there are some modifications that need to be made to it, unless you are familiar with transmission assembly you would be better off going with a t5 5 speed if you want overdrive.
Tommy
59 apache 1/2t
261 short stepside
