3 members (Rich'sToys, Nick in Manitou, Bill Hanlon), 88 guests, and 2 robots.
Topics128,062
Posts1,055,854
Members48,428
#97715 10/22/2006 1:30 AM
I
I Offline
anyone know of a place that works on or repairs the high lo horn system?
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#97716 10/24/2006 1:53 PM
you should be able to fix them yourself... they cant be that complicated.
Another quality post.
Real Trucks Rattle
#97717 10/24/2006 3:58 PM
Ex Hall Monitor
Ex Hall Monitor
You might check Hemmings Motor News site.
#97718 10/24/2006 5:15 PM
The Horn Works is not cheap ($200/pair of horns) and he gives a good sales-pitch.
I have asked your question a few times and no one has yet responded with first-hand experience in dealing with a horn restorer.
#97719 10/25/2006 2:04 AM
I
I Offline
Rusty, these horn arent something you can just poke and dig a screw driver around in. Several el circuts in them. Loks to be a couple of place to adjust them, but who knows what to adjust. Looks to be a set of points in them, along with a viberator, and some diodes. Cloth wiring eveywhere in there. Too bad that horn guy only does 64 and up. Got a set from a 50 truck, but there differnt than the 47 ones, and only the lo one works from that set. Thouhgt i could just change out the inside part, as i powered coated the shell and cover of mine, but the bolt patterns are differant. So typical of chevy parts. The same,but not really. Maybe i should find someone to teach me how to restore them, and start a businees.
Jeff
1953 3/4-ton
#97720 10/25/2006 5:23 AM
I'm gonna put air horns in mine when I get to that point. I want to scare people when I use the horn, LOL,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#97721 10/25/2006 1:31 PM
DANGER! Make sure all breakable objects are clear of work area prior to working on any horn. Take horn apart and close the contact point's in increments of 1/32 (of a turn) to the close, adjustment is pretty important to get the viberator to work propery.. Using heavy (I use 10 ga.) wires for groung and positive, ground horn to battery and touch the positive wire to terminal after each adjustment.When horn works retighten the lock nut.Good luck,
P.S.Bet you a buck you jump when it first works so insure that no objuct are knocked off work bench. Beaver 53
#97722 12/04/2006 12:10 AM
V
V Offline
That is funny!
