| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#97715 10/22/2006 1:30 AM | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | anyone know of a place that works on or repairs the high lo horn system? | | |
#97716 10/24/2006 1:53 PM | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | you should be able to fix them yourself... they cant be that complicated.
#97717 10/24/2006 3:58 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You might check Hemmings Motor News site.
#97718 10/24/2006 5:15 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The Horn Works is not cheap ($200/pair of horns) and he gives a good sales-pitch. I have asked your question a few times and no one has yet responded with first-hand experience in dealing with a horn restorer. | | |
#97719 10/25/2006 2:04 AM | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Rusty, these horn arent something you can just poke and dig a screw driver around in. Several el circuts in them. Loks to be a couple of place to adjust them, but who knows what to adjust. Looks to be a set of points in them, along with a viberator, and some diodes. Cloth wiring eveywhere in there. Too bad that horn guy only does 64 and up. Got a set from a 50 truck, but there differnt than the 47 ones, and only the lo one works from that set. Thouhgt i could just change out the inside part, as i powered coated the shell and cover of mine, but the bolt patterns are differant. So typical of chevy parts. The same,but not really. Maybe i should find someone to teach me how to restore them, and start a businees. | | |
#97720 10/25/2006 5:23 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I'm gonna put air horns in mine when I get to that point. I want to scare people when I use the horn, LOL, Scott | | |
#97721 10/25/2006 1:31 PM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | DANGER! Make sure all breakable objects are clear of work area prior to working on any horn. Take horn apart and close the contact point's in increments of 1/32 (of a turn) to the close, adjustment is pretty important to get the viberator to work propery.. Using heavy (I use 10 ga.) wires for groung and positive, ground horn to battery and touch the positive wire to terminal after each adjustment.When horn works retighten the lock nut.Good luck,
P.S.Bet you a buck you jump when it first works so insure that no objuct are knocked off work bench. Beaver 53 | | |
#97722 12/04/2006 12:10 AM | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | | | |
