11 members (frogfarmer, Scott, Wayne67vert, cmayna, 48jim1ton, Wally / Montana, gswbbc, Gdads51, panel fan, FAST55, 1 invisible),
112
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | So after about a million searches I decided to try, the Tech Tips section. Cool! I have an AC Delco S-2 filter. The big one. That is why the filters that my friends keep telling me to use just floats around in the big deep hole. Thanks to Pat Doonan I have the part number I need. Thanks to all who help on this site. FYI the filter is Fram C31PL available at the local FLAPS. Makes you wanna smile.
Steve H
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Good searching, Steve.
Thanks for posting a brand/part-number.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah Steve, tks, that filter was not all that common back in the day so you can imagine how seldom it's seen now days. I'm even surprised that you can still get an element that fits that tall canister.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Found the filter at Autozone. The filter case has a drain on the bottom that and a bit of hose makes the messy part of the oil change so much less messy. Mine has a brass valve that works just fine. So I wanted to keep it and be able to use it. And the extra oil it holds hurts nothing. Better than trying to get a quart of oil out with rags and a can. Just drain and go.
Steve H
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Question. When changing the oil on one of these 216/235 with an oil filter. Do you fill the oil canister separately when you fill the engine? Add extra oil to the engine when you fill it?
John | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | I just put 5 quarts in the engine and run for about 5 minutes. Then I put in 2 more quarts and check the level on the dip stick. Seems to be OK. The 5 minute run lets the canister fill and I don't have to mess with the filter after I have cleaned it all up. If you don't get the lid on just right it will leak like crazy. So when that lid is on I like to leave it alone. Hope this helps.
Steve H
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It depends on how/where you oil filter canister returns oil to the block. Some empty at the bottom of the canister and some empty higher up the canister.
My by-pass canisters empty higher up the canister. After removing the filter, sucking out the oil, and putting in the new filter: - Fill the engine with specified amount of oil (5 qts). - Fill the 1-qt oil canister with a 1-qt of oil (fill the 2-qt canister with 2 qts of oil). - Start and run the truck for several minutes. - Turn off the engine, clean up, and have a home-made beer. - Check the oil level, and top up as necessary.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I believe mine has one line off the bottom and one comes off the side of the canister. For some reason I'm tyhink C-21 filter, but I may be wrong. I have the oil ports plugged right now on the engine. John | | |
