1 members (Hotrod Lincoln),
60
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#97644 10/18/2006 4:23 AM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | The distributor is missing a part. This 1941 216 dist. is missing the bakelite plug at the base of the greasing mech.
Where can I find one?
Looks as if it would wear out because it rubs under spring tension against the distributor main shaft all the time.
I have looked on the parts web sites but none is listed.
My freind went to his stash spot and brought me back another distributor to rob the part out of, but it won't budge. So I am letting it soak in solvent and thought I would make a post just in case. :confused:
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
#97646 10/18/2006 5:41 AM | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Isn't bakelite the same stuff that the cheap electrical boxes are made out of for wiring your house? It looks like the same brown stuff to me. If so, could you use that and a dreml to fabricate the piece you need? | | |
#97647 10/18/2006 2:14 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 |
#97648 10/18/2006 2:16 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | 641 I dont have one to look at, but I think you are correct. And that is an option I am looking into.
#97649 10/18/2006 9:13 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 |
#97650 10/19/2006 2:05 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | I was able to salvage the part needed from another distributor. Problem resolved. Thanks!
