0 members (),
38
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 | I have 3 small holes in the drivers side bed panel. They are located right in front of the rear fender. Does anyone know what went there? The spare tire is mounted under the bed, so I don't think it is that.. It seems like I have seen some sort of bracket holding a gas can maybe? Thanks
Tom
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | something a PO added sometime in the last 70 years, nothing factory
Bill | | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 | There was a bracket mounted on a 39 that sold at Barrett Jackson in 2010, It looked like it held three small gas cans? Original part or an aftermarket?
the truck was green and black and is on the web if you goggle 1939 chevrolet truck. Look at the images section. thanks
Tom
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | aftermarket, unless you can find some info on it as a GM accessory - that sort of thing was relatively common on pre-war cars and trucks, and carried gas/oil/water - like theseBill
Tom
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | On a 1939 it's likely something someone added along the way. Your truck is 74 years old, there will be a lot of things like this that don't have an answer. | | |
