2 members (RLB, TUTS 59), 107 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
I have 3 small holes in the drivers side bed panel. They are located right in front of the rear fender. Does anyone know what went there? The spare tire is mounted under the bed, so I don't think it is that.. It seems like I have seen some sort of bracket holding a gas can maybe?
Tom
something a PO added sometime in the last 70 years, nothing factory
There was a bracket mounted on a 39 that sold at Barrett Jackson in 2010, It looked like it held three small gas cans? Original part or an aftermarket?
the truck was green and black and is on the web if you goggle 1939 chevrolet truck. Look at the images section.
thanks
Tom
aftermarket, unless you can find some info on it as a GM accessory - that sort of thing was relatively common on pre-war cars and trucks, and carried gas/oil/water - like these
Thanks!
Tom
On a 1939 it's likely something someone added along the way. Your truck is 74 years old, there will be a lot of things like this that don't have an answer.
My 46 GMC on Photobucket
What you are dealing with is a version of these, common to find them in this or similar color shades. These commonly appear on eBay in NOS condition or good used. Expect to pay in the $100 dollar range for a good set.
http://www.flickr.com/photos/advance-design_parts_co/10089772153/lightbox/
Kerosene road flares, several brackets were available, you usually find them stacked on inner cowls or bed sides. There were several manufacturers and at least on the GMC side versions appear in the master parts book specifically the 1937-53 version I have. When I get a chance I will look it up and post the parts/section numbers.
So how popular? Here you can see a GMC with a box of them on the floor, they were in the tool box pan.
http://www.flickr.com/photos/advance-design_parts_co/8130539326/in/set-72157631870734114
Here is a bracket on the forward DS bed side, flares missing but you can see the lock down with a small tang.
http://www.flickr.com/photos/advance-design_parts_co/8626465790/in/set-72157631870734114
Another type (this version appears in 60's Chevrolet truck material).
http://www.flickr.com/photos/advance-design_parts_co/10092819666/
http://www.flickr.com/photos/advance-design_parts_co/8262113533/in/set-72157632220275326
In 30 trucks I have seen 4 of these installed from complete to bits and pieces.
And again another that appears in 60' Chevrolet materials. I have found a couple of these in trucks, the are available for as little as $10 near new.
http://www.flickr.com/photos/advance-design_parts_co/10092763184/
http://www.flickr.com/photos/advance-design_parts_co/8262113765/in/set-72157632220275326
