Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 55 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#975322 09/29/2013 7:59 PM
I will be putting in a automatic trany in my 65 gmc it had a straight stick in it where would be a good place to get a column for a automatic
Bob May
I don't know. Half the fun of these old trucks is the original equipment. I spent 2-hrs fine tuning the idle, mixture, cleaning the plugs and setting the dwell and timing.
Tom
1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
I think the Chevy and GMC trucks will swap in up to the mid to late 70's. Or you could get an aftermarket Ididit steering column or Flaming River column. .
Tony Smith, aka "4-5-6 Chevy Trucks" here on the Stovebolt ... and he will help ya with any other pieces parts ya need to make the column work too.
Here's a link for ya, email or call him..... http://4-5-6chevytrucks.com/
Country Boy,
I actually just saw this on Craig's list.
http://omaha.craigslist.org/pts/4066759785.html
Might be worth a call. Says he's got two automatic steering columns, $325 each. Don't know if that's a good price or not, seems a little steep but maybe he'll come down.
Tom
Automatic columns are CHEAP! many folks want to go standard tranny or after market floor shift and the old Automatic column is worthless. I got mine for my '71 C-10 for $15! I tore it down and rebushed it and added a new Shift indicator, fiber optic light socket, and turn signal assembly and repainted it. I didn't NEED to do all that stuff, but you know how it goes. Total cost; under $100 for an essentially brand new OEM column! Put an ad in "parts wanted" here on 'the 'bolt" or poke around the local JY. What you want is a '62-'72 unit. The '73 up have the ignition switch on the column. Look at the '71 C-10 pics under "More pix on Photobucket" in my signature line to see the one I described.
Have fun,
Les
Have fun,
Les
Worthless, is not the word I would use for describing a '63-'66 Chevy truck automatic steering column. If you want all of the wiring to be correct & be able to plug-n-play and look correct, you will need a '63-'66 Chevy/GMC truck automatic steering column.
Thanks for the vine, Hot Rod John.
