8 members (Ponchogl, Gabes-trucks, Wickedbass, Otto Skorzeny, 52Carl, dt235sd, BC59, 1 invisible),
138
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,076 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Got tired of shuffling the cans around to get to the one in the back of the 18" deep shelves so I made a couple of these shelves from some 2x8's that I had in the shop. Now I can see all the tops of all the cans at a glance. http://www.pbase.com/dennygraham/image/151322365Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Denny,
What is the shelf life on those cans of paint? Unopened/unused? Opened and partially used?
How do you clean the nozzles after use (or, do you use a new nozzle for each use)?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | lumber must be cheap around there to be using 2x for that - looks like yer going into business, hit all the 'case lot special' days?  Bill | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not sure Tim, some of those cans are from my move to the airport in '85 and they still spray, I run into a dud every once in a while. After each use I flush the nozzles with a the tube on a can of brake cleaner, the inside of the nozzles fit right over the tubes. Had a whole pile of 2x8 eight footers that the previous owner left me last year Bill. Routed a 1/2" deep dado for the shelves and it gives me a real sturdy shelf unit. And Bill, you know how anal I get about getting just the right color for my restoration projects, so when I need brown I pick up every shade of brown I can find, or white or black or what ever. For instance, you got gloss blacks, flat blacks, semi- gloss blacks, chassis blacks, radiator black, chalkboard black, black lacquer, high-temp blacks, you get the picture. Don't even get me started on the proper engine gray. Multiply that by all the basic colors and the fact that I buy paint for the radio restorations and you can see where it all comes from, very few duplicates. But, these shelves don't have a very big foot print, they're attached to the back and end cap of a larger 24x24 shelf used for Rubbermaid containers and again, they free up the 18x36 All-Steel shelf unit I had in the barn for bigger things. Denny G
| | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Denny,
You have inspired me. I have a shelf of rattle cans. Cases of the colors I use regularly, but then the menegiere of colors that one will accumulate. And they are just stuffed one in front of the other on the shelf. This may help to simplify the process. Just have to remember to hang onto the lids. | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | I keep all of my rattle cans in an overflowing box on the floor so I can continuously maintain my cat-like agility, avoiding tripping over the mostly empty, clogged nozzled stale paint cans. Hello, my name is Carl and I am a hoarder. I'm not on that TV show yet since my wife won't let me in the house anymore.
| | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | I keep all of my rattle cans in an overflowing box on the floor so I can continuously maintain my cat-like agility, avoiding tripping over the mostly empty, clogged nozzled stale paint cans..... Another "bad day in the garage" Carl?  | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | You have to hate people that are to organized.....They must have to much time on their hands..... :-) John | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Oh, that's just what I have John, to much time on my hands. 6.5 acres to mow and spray, dozens of oak, hickory and maple trees to tend to. Over 1,000 feet of overgrown privet hedge to keep trimmed, nearly 100 bushes and plantings that need trimming around the house. 400 foot of gutter around the house and barn that need cleaning a few times a year. 2600 sq.ft. of blacktop drive and parking that needs sealer every two years. A bare open horse barn that I'm trying to clean out, wire and turn into a civilized shop area. Tractor, Track-Vac, mowers, snow & sod plows that need restoring, 1960's end loader that needs restoration and adaptation. Not to mention the hardwood floor to lay down and the other honey do projects. Made a BIG move of all the stuff in the picture all by my self over the last year from the old house to the new old house. That's just a few of the things that I do my self in my spare time. Organized you say??? Spend most of my days looking for things that often times I can't find for months. But I must have to much time on my hands, cuz I am guilty of stealing a few hours of sleep out of my typical 14-16 hour day, seven days a week since March of 2012. Got the pictures to prove it to John. http://www.pbase.com/dennygraham/new_houseDenny Graham Just sittin' round doin' nuttin' in Sandwich, IL
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Oh, that's just what I have John, to much time on my hands. 6.5 acres to mow and spray, dozens of oak, hickory and maple trees to tend to. Over 1,000 feet of overgrown privet hedge to keep trimmed, nearly 100 bushes and plantings that need trimming around the house. 400 foot of gutter around the house and barn that need cleaning a few times a year. 2600 sq.ft. of blacktop drive and parking that needs sealer every two years. A bare open horse barn that I'm trying to clean out, wire and turn into a civilized shop area. Tractor, Track-Vac, mowers, snow & sod plows that need restoring, 1960's end loader that needs restoration and adaptation. Not to mention the hardwood floor to lay down and the other honey do projects. Made a BIG move of all the stuff in the picture all by my self over the last year from the old house to the new old house. That's just a few of the things that I do my self in my spare time. Organized you say??? Spend most of my days looking for things that often times I can't find for months. But I must have to much time on my hands, cuz I am guilty of stealing a few hours of sleep out of my typical 14-16 hour day, seven days a week since March of 2012. Got the pictures to prove it to John. http://www.pbase.com/dennygraham/new_houseDenny Graham Just sittin' round doin' nuttin' in Sandwich, IL Denny, That sure was a wordy way of saying, "KMA". I don't keep my work space as clean and organized as you because I am a habitual slacker, not because I don't have anything better to do. Reading about your attention to details, regardless of the topic, has motivated me to change my ways. BTW, I'm pretty sure John was poking fun. His comment is more telling of his problems than of yours. Carl
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just my thin skin Carl, can't take much poking I'm very sensitive you know! Denny G
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | MY GOD Denny You have enough rattle cans to paint my house. Is there a need? | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Just my thin skin Carl, can't take much poking I'm very sensitive you know! Denny G Nothing toughens the skin like constant poking. I'll try to keep it lighthearted.
