1 members (baldeagle),
55
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 59 | I will be putting in a automatic trany in my 65 gmc it had a straight stick in it where would be a good place to get a column for a automatic
Bob May
| | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | I don't know. Half the fun of these old trucks is the original equipment. I spent 2-hrs fine tuning the idle, mixture, cleaning the plugs and setting the dwell and timing.
Tom 1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I will be putting in a automatic trany in my 65 gmc it had a straight stick in it where would be a good place to get a column for a automatic I think the Chevy and GMC trucks will swap in up to the mid to late 70's. Or you could get an aftermarket Ididit steering column or Flaming River column. . | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I will be putting in a automatic trany in my 65 gmc it had a straight stick in it where would be a good place to get a column for a automatic Tony Smith, aka "4-5-6 Chevy Trucks" here on the Stovebolt ... and he will help ya with any other pieces parts ya need to make the column work too. Here's a link for ya, email or call him..... http://4-5-6chevytrucks.com/ | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Country Boy, I actually just saw this on Craig's list. http://omaha.craigslist.org/pts/4066759785.htmlMight be worth a call. Says he's got two automatic steering columns, $325 each. Don't know if that's a good price or not, seems a little steep but maybe he'll come down.
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Automatic columns are CHEAP! many folks want to go standard tranny or after market floor shift and the old Automatic column is worthless. I got mine for my '71 C-10 for $15! I tore it down and rebushed it and added a new Shift indicator, fiber optic light socket, and turn signal assembly and repainted it. I didn't NEED to do all that stuff, but you know how it goes. Total cost; under $100 for an essentially brand new OEM column! Put an ad in "parts wanted" here on 'the 'bolt" or poke around the local JY. What you want is a '62-'72 unit. The '73 up have the ignition switch on the column. Look at the '71 C-10 pics under "More pix on Photobucket" in my signature line to see the one I described.
Have fun,
Les
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Automatic columns are CHEAP! many folks want to go standard tranny or after market floor shift and the old Automatic column is worthless. I got mine for my '71 C-10 for $15! I tore it down and rebushed it and added a new Shift indicator, fiber optic light socket, and turn signal assembly and repainted it. I didn't NEED to do all that stuff, but you know how it goes. Total cost; under $100 for an essentially brand new OEM column! Put an ad in "parts wanted" here on 'the 'bolt" or poke around the local JY. What you want is a '62-'72 unit. The '73 up have the ignition switch on the column. Look at the '71 C-10 pics under "More pix on Photobucket" in my signature line to see the one I described.
Have fun,
Les Worthless, is not the word I would use for describing a '63-'66 Chevy truck automatic steering column. If you want all of the wiring to be correct & be able to plug-n-play and look correct, you will need a '63-'66 Chevy/GMC truck automatic steering column. Thanks for the vine, Hot Rod John. | | |
