| | | Forums66 Topics128,042 Posts1,055,602 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 23 | Dies anyone know where you can the interior door/window trim that fit on the top of the door? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Is the low cab doors the same as the 37's? If it is are you talking about the two pieces that go over the door at the top, and has a metal clip in the middle covering where they join? If so, I MIGHT be able to help. | | | | | Joined: May 2009 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 23 | Yes those are the exact parts I need for both sides. Thanks | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | The doors from a 36 low cab are different than a 37 and do not fit a 37, I've been told. I'm not sure if this affects the trim pieces as well. One guy I know has a 37 and another is building a 36, and trying to swap spare parts they've found that there are a lot of differences between the two. | | |
