10 members (Guitplayer, 2-Ton, baldeagle, walter74, Eisenholtz, Peggy M, joe apple, WICruiser, Bill Hanlon, dt235sd),
66
Mod | | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 41 | I have a 48 3/4 ton and I changed the master cylinder to a duel system using a master cylinder for a 1968 chevy truck. I put the front brakes on the front port and the rear brakes on the rear port of the master cylinder. I bought all new huck wheel cylinders. I cant bleed the system and achieve a high pedal. I have the wheel cylinders adjusted up so the drums are hard to turn. I want the pedal to be as hard as a rock. right now the pedal is low. maybe 4 inches from the floor and soft...... any suggestion. need help lol | | | | | Joined: Nov 2012 Posts: 441 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 441 | Viagara.......Just kidding. Any air in the system? I've replaced everything on occasion and still come up with a soft pedal. I have a friend with a power bleeder system and that was the only way the pedal came up. IT may be possible that for your new setup, that is where the pedal will land for solid brakes. Do it fade at all? Best, Joe 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Do you have the push rod that goes into the master cylinder adjusted? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy pjberg, did you bench bleed the master before you installed it? If you bleed with a bleed screw in each system open at the same time that will allow a full stroke of the master cylinder piston, hope that helps. | | | | | Joined: Jul 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 41 | How do you adjust the push rod correctly any way | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jul 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 41 | Pedal doesn't fade and now I got about half pedal. I took it out for a drive and the brakes stopped the truck. Is it ok that I'm using DOT3 brake fluid? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | DOT 3 is the same as the "Super #11" fluid that's suggested in the shop manual. DOT 4 will be fine as well. Do not use the silicone based DOT 5 (purple in color), as it will not mix properly wit the glycol base fluids, and is incompatible with the rubber components in the brake system.
Bill Burmeister | | | | | Joined: Jul 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 41 | I believe if the pedal did fade as you pushed on it, it would be the master cylinder or a leak | | | | | Joined: Jul 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 41 | Amtrak Joe your a fun guy lol | | |
