1 members (LAROKE), 36 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#974491 09/26/2013 4:51 AM
I have a 48 3/4 ton and I changed the master cylinder to a duel system using a master cylinder for a 1968 chevy truck. I put the front brakes on the front port and the rear brakes on the rear port of the master cylinder. I bought all new huck wheel cylinders. I cant bleed the system and achieve a high pedal. I have the wheel cylinders adjusted up so the drums are hard to turn. I want the pedal to be as hard as a rock. right now the pedal is low. maybe 4 inches from the floor and soft...... any suggestion. need help lol
pjberg #974501 09/26/2013 7:08 AM
Stovebolt Photo Moderator
Viagara.......Just kidding. Any air in the system? I've replaced everything on occasion and still come up with a soft pedal. I have a friend with a power bleeder system and that was the only way the pedal came up. IT may be possible that for your new setup, that is where the pedal will land for solid brakes. Do it fade at all? Best, Joe
1947 - 3800 dually known as "Deadwrench"
Link to a few photos
In this world there are givers and takers. The takers eat well, the givers sleep well.
pjberg #974507 09/26/2013 7:45 AM
Do you have the push rod that goes into the master cylinder adjusted?
pjberg #974546 09/26/2013 10:46 AM
3B Offline
Hy pjberg, did you bench bleed the master before you installed it? If you bleed with a bleed screw in each system open at the same time that will allow a full stroke of the master cylinder piston, hope that helps.
pjberg #974739 09/27/2013 2:07 AM
How do you adjust the push rod correctly any way
pjberg #974750 09/27/2013 7:35 AM
pjberg #974827 09/27/2013 12:34 PM
Pedal doesn't fade and now I got about half pedal. I took it out for a drive and the brakes stopped the truck. Is it ok that I'm using DOT3 brake fluid?
pjberg #974916 09/27/2013 9:12 PM
DOT 3 is the same as the "Super #11" fluid that's suggested in the shop manual. DOT 4 will be fine as well. Do not use the silicone based DOT 5 (purple in color), as it will not mix properly wit the glycol base fluids, and is incompatible with the rubber components in the brake system.
Bill Burmeister
pjberg #974985 09/28/2013 10:12 AM
I believe if the pedal did fade as you pushed on it, it would be the master cylinder or a leak
pjberg #975328 09/29/2013 8:14 PM
Amtrak Joe your a fun guy lol
