| | | Forums66 Topics128,013 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | My clutch went out on Wed. Got it trailered home yesterday and this is what I found. Clutch parts Anybody else have a clutch come apart like this? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | never had it happen, I'd say it was defective from new, maybe another Chinese mistake
Bill | | | | | Joined: Dec 2008 Posts: 898 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 898 | I'm thinking on the same lines as red58. I wouldn't think a 235 would have what it takes to tear a clutch up like that. The clutch lining and pressure plate still look to be in good condition.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | How chewed up are the bolts that hold the flywheel on? Maybe had the wrong bolts installed that hold the flywheel on and they caused the disc to hit them? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Don makes a good point those bolts need to be factory, nothing else really works as they have a very thin head. They should also be replaced if you remove the flywheel for any reason, cheap insurance against stretched or galled threads. | | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | The flywheel bolts looked correct when I put the new clutch in tonight. That clutch was installed back in 1991, ran until 1995, parked until this year and ran daily for the last month. | | |
