| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | which engine do you think would get better mileage, 1956 265, 1970 350, 1958 235? Mated to T-5 and 3.42 open rear in S-10 chassis (working on rat rod), have several motors laying around. I'd like to stay low on investment, so carbed, maybe elec ignition, but no aftermarket fuel injection or anything. Hoping for around 18-19mpg. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I would bet that the 350 would be the easiest to squeeze mileage out of, then the 235 and the 265 last. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | For economy it's hard to beat a turbo diesel. You could see mid 20's or low 30's MPG with the right engine and gearing in a small truck. | | | | | Joined: Jun 2012 Posts: 197 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 197 | Why would a 265 SBC be the worst choice for economy?
Some of my crap: 1963 C-30 flatbed dually 292/SM420 1965 C-10 LWB fleet 250/column shift 3 speed 1965 C-30 9' stepside 250/SM420/4.10 gears (my DD) Website I made for my crap: http://www.66submarine.com | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | You can get 18-19+ out of all of them. All factors being equal. As far as the 350, it depends on year and HP. The 1970 would be pre emissions and would probably get good mileage. But a rat rod is a hot rod and hot rodders don't get good mileage except with their right foot. If you are a "smoothie" Hot Rodder, you will be OK. EFI does not give mileage. The wrong carb/adjustment/brand= BAD mileage.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I'd say the 265 would get the best mileage with that gearing. An aluminum intake with Q-jet carb & HEI. wood work slick. If you want a lot of power to show off the 350 would be awesome. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I have often thought of a 265 with a throttle body off a 4.3, electronic ignition and a 700R4 trans and a different ration rear end. Another I was thinking of was a 4.3 with a throttle body, 4l60E transmission, and a rear end. The 4.3 setup delivers 17-21 mpg on my 1994 1/2 ton. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Lots of engines will give that mileage but he has the three mentioned. Two V8's and a straight 6. The 265 mileage is lower than the 235 and 350 and may not achieve 18-19MPG like the other two. All gearing the same. etc., after reading some original mileages given, I have to say the 235 is the most likely and the 265 is the least likely to get there. The newer V8's get past 20. That's technology for ya. Remember, gas mileage is almost the most "exaggerated" subject there is on the planet.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | well the stock 55 I had with the 265 and power glide would get
17.999999999999999999999999999999999999999999999999999999999
this would have been back in 61 when we did not think of it that much........ Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | There's a joker in every crowd.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | it is true,, just like this one it was mint, made 2 round trips to Long Beach, Calif from Tx paid $650 for it, got out of the Navy in 63 and traded it in for our first new car a 63 corviar..
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I believe you. That is pretty good mileage. Bet you wish you still had that one. We all have two or three we wish we still had. In my case it's a 1934 Plymouth coupe with rumble seat (my first car at 15, $90 in 1961). Complete and running good, a 1956 Chevy 210 and a 1967 Mustang.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | one like this would have been my first, back in 59 and to stay on topic I have no idea about the gas mileage, it had a 49 merc engine.. for sure Bart, I can think of many that I would like to have back.. the 52 I just sold and my 52 truck prior to that
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | About a 1000 factors to consider but one thing is for sure, a smaller displacement engine will get better mileage if both the larger and smaller are of the same design. If a 265 has the same internals as a modern engine like modern oil, ignition, low friction rings and valve train, and run at a higher temp like the newer ones then IT WILL get better mileage figures. The 235 has a lousy fuel induction system and exhaust but was a great engine for it's time. With the siamesed ports on both intake and exhaust it's limited on economy improvements. Of course if half pedal will give 70mph with a 350 and it takes 3/4 pedal to do the same with a 265 then throw all the above out the window.
Evan
| | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Finished building my 51 Chevy/Shortbed last year, drove about 1500 miles this summer. My set up is, 4.3v6 Throddle body fuel injection, 700r4 Trans., 272 rear/end highway gears. At 60 miles per hour she will run around 1900 to 2100 RPM consistently gives 23 miles per gallon. Needless to say I am very happy with the power and performance of this build. Its just so much fun to cruise with it, highway or back roads. | | |
