5 members (Wayne67vert, Gray_Ghost, tclederman, Ridgeback, 1 invisible), 56 guests, and 5 robots.
Topics128,021
Posts1,055,372
Members48,420
#974475 09/25/2013 11:54 PM
I'm currently running a Carter YF 966S on my truck. The main jet has the markings 120/162. The low speed idle tube has the markings 11-232S on the top. I just rebuilt a Carter YF 2100S with main jet markings of 120/164 and low speed idle tube marking of 10.
I'm not sure if these markings have anything to do with jet diameter size. However, they are both fine carbs for the 1956 235 inline.
I would like to change over to dual Carters. Are these two compatible based on the model numbers and jets?
Thanks.
Mark
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
MarkT #974516 09/26/2013 8:52 AM
You might want to contact carbking. He often responds to STOVEBOLT.
Attached is his own site.
http://www.thecarburetorshop.com/Orderinfo.htm
Drew
MarkT #974537 09/26/2013 10:22 AM
You need the exact same carbs, jetted and set the exact same. There are lots of differences in design of carbs even though they look and perform the same. On a dual setup, both have to work the same or half the engine cold be slight rich or lean from the other half. It makes tuning very difficult when you are working against each other.
The Carter numbers indicate size, so yes, they are different.
Joe
MarkT #974545 09/26/2013 10:44 AM
Carburetion specialist
The general rule FOR BEST RESULTS is to use the exact carburetors with the exact same calibration.
Now the question is, will what you have work? Probably, but so will hiring a 15 year-old to stand on the running board and pour fuel into the engine out of a leaky boot!
Will it work as well as you want it to? Depends on the skill of the 15 year-old wink or in the case of two different carbs it would depend on your access to a chassis dyno, a machine shop, and your skill as a tuner.
Would I do it? No.
And while there are no 966s or 2100s currently on ebay, there have been several of each sold in the last month. You can match either with a little patience.
Jon.
The Carburetor Shop
MarkT #974550 09/26/2013 11:04 AM
Both work great separately. But I get what you're saying regarding calibration differences and performance if used together. No leaky boots or 15 year olds around here either.
Thanks.
