0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 17 New Guy | | New Guy Joined: Jul 2013 Posts: 17 | I was in the process of removing the manifold on my 46 3800 to fix an exhaust leak. Everything was going remarkably well, even the bolts were coming out nicely when..."tink" and the rear ear fell into my hand...
So now I'm in need of a manifold.
The casting number on the intake looked like 3836160, Googling that brings up a 235 water pump. One or more of the 3's might be an 8 but the 6160 is pretty certain.
The exhaust side has no numbers I can identify due to corrosion.
The exhaust outlet in straight down and the carb pad is for the smaller 216 carb.
Block number if it helps is 3835253.
Any help would be appreciated and if anyone has one that would work Please let me know.
| | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | I believe that can be welded. Make some calls to shops that weld cast iron.
1951 Chevy 3100 Some days you get the bear. Some days the bear gets you.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 3835253 : 1948-489 216
I think the intake/exhaust manifolds that year were the same for 216/235?
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Didn't some of the 216 engines have the D shaped exhaust ports and then later the square or rectangular ones? When was the change over?
John | | | | | Joined: Jul 2013 Posts: 17 New Guy | | New Guy Joined: Jul 2013 Posts: 17 | I could get the ear welded but figured for the cost of welding I might find another manifold altogether. Also even after extensive soaking in pb blaster all 4 bolts broke upon trying to split the intake and exhaust. A torch might help get them out but I'll still have the crack to deal with.
I'm pretty sure all the early 216 manifolds were similar but the casting number has me thrown off.
Thanks for all the responses.. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Post in the parts wanted section of the forum. Could get lucky, include your cast number in request to make sure you get the correct exhaust flange.
| | | | | Joined: Jul 2013 Posts: 17 New Guy | | New Guy Joined: Jul 2013 Posts: 17 | Will do, It does have the horn bracket cast into it as well.
Thanks.. | | |
