3 members (Roy Rodgers, Oswald, Brian Moore), 124 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
#973729 09/23/2013 12:03 AM
hey all. Gone for a while, busy! Still driving the truck. I think I have a problem, I'm having a lot of play in my pinion when I disconnect the drive shaft.
I checked my Hollander exchange which goes covers 1946-56. It says that 1946-56 3/4 and 1 ton rear end pinion bearings are all the same. Is that true? In that case I could look for a 1948-55 and 1955-59 rear end? Some input is really appreciated, I'm trying to keep this truck an almost daily driver. 6 years now and going strong
I LOVE MY TRUCK
1959 Chevrolet Apache 38 Panel Truck in the Gallery
If you don't need the truck for everyday use, pull the bearing and take it to a bearing shop. There should be a number on it and if not they can measure it and replace it. You might need a speedy sleeve for the yoke shaft (or whatever it's called) where the seal has been riding, you'll see when you get it out.
Bruce
My Trucks
Stuff I Collect
Moderated by  Dusty53
