| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | hey all. Gone for a while, busy! Still driving the truck. I think I have a problem, I'm having a lot of play in my pinion when I disconnect the drive shaft. I checked my Hollander exchange which goes covers 1946-56. It says that 1946-56 3/4 and 1 ton rear end pinion bearings are all the same. Is that true? In that case I could look for a 1948-55 and 1955-59 rear end? Some input is really appreciated, I'm trying to keep this truck an almost daily driver. 6 years now and going strong | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | If you don't need the truck for everyday use, pull the bearing and take it to a bearing shop. There should be a number on it and if not they can measure it and replace it. You might need a speedy sleeve for the yoke shaft (or whatever it's called) where the seal has been riding, you'll see when you get it out.
Bruce | | |
