| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Been dealing with engine overheating for some time now and finally had the block flushed clean...got tons of rust and scale out. It's not all back to drivable condition yet but will be soon. Started it the other day just in the shop and let it idle for a bit.. Just at idle it runs at 195 which kinda scares me..seems way too high for idle. Ambient temp on that day was about 85. Just kinda nervous about this but will see soon enough. Does this not seem high to you guys just sitting in a garage at idle...? True, it has only an elec fan and only moves about 1000cu ft/sec... maybe less...
Like I said, we'll find out soon enough but if it overheats while climbing some grades I would not know what else to do ? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | My opinion, 195 at idle is OK. Also, if using a stock temp gauge there is some degree slop there. I think when driving and air rushing threw the radiator, it would be fine.
Drew
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Thanks Drew... This was meas. with a heat gun. The temp gauge needs to be replaced. Guess I'm just nervous after dealing with this problem for so long | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | What temp thermostat you have in it?? | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | I'm pretty sure it's a 180. If it's a 160 I'm really worried...just can't recall now. I'll be able to drive/test it this week so will soon see. I know it will idle ok, be fine on flat ground cruising but worried a bit about under load up a grade. It's just been such a battle to get to the bottom of this that I'm a tad nervous....we all want to see these type problems get solved...once and for all. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You might want to get rid of that electric fan and go back to the original type fan mounted to the radiator. Some electric fans can actually make things worse for air flow. | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | I don't disagree at all. To do that I'll need a new water pump and Dave's relocation plate. Almost did that but my mechanic was really nervous about drilling those two holes in the block to mount it. I would be much happier with a big belt driven fan myself and have that in mind if this set up does not work out. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Does it stay at 195 indefinitely at idle or did you get scared and shut it off as soon as it hit 195? I understand if you did shut it off right away. I am always paranoid after a rebuild. I once put off even starting a complete rebuild for 2 weeks out of pure fear. If it stays at 195 at idle for extended periods, I wouldn't be concerned. I probably wouldn't leave it at idle unattended until I drove it around for awhile to see what temperature it runs at while driving around.
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | It stayed at that temp for a while...still does not have the tranny back in so could not drive it but will this coming week. At some point during the whole process the temp gauge got trashed so theres one on order. The temps noted were taken with an IR gun. This was just a test and no one left it alone for any time... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the fan setup you describe is likely the entire problem, it should not run 195 at idle, but you should get more than "pretty sure" about the stat rating, you might have been given a 195, or have a defective 180, take it out and check, don't trust the numbers stamped on it, test it in a pan of water on the stove with a good thermometer
Bill | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You should get a good box fan and put it in front of the grille and see what the temperature does with some good air flow through the radiator. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I've re-read your very first post and there are "flags" in it. First off hopefully none of the "tons of rust and scale" are not now in the radiator. Flag #2, a fan that pulls only 1000 will not truly get the job done. Especially in the hot summertime. I'd also say wait until you get a good guage and see what happens.
I've ran electric fans quite a bit without any problems. I've also had trucks idle, while working on them, for quite a while in the shop and still maintain correct temp. The correct fan is a must whether it is a mechanical fan or an electric!.... and a fan shroud is almost a must on some of these modified vehicles. | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | 1000cfm! My farts push more air. Check out perma-cool. The have nice 3500cfm that are 13"x13" wide and like 1-1/2" thick. I have one, no fan shroud, fiberglass hood without holes by the latch like a factory and I never hit 190. The fan is a bummer. Also I recommend running purple ice as an additive in the antifreeze. Sounds lame but it helped. I run it in my cummins and my small block powered c-10.
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Hey Hollow.... You have such a way with words.... but I'll look at it  | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | I know, I know. I talk Perdy. But yes, check out perma cool. It's a bummer to have to cough up more coin, but it is worth it. The relay kit is nice also. Fan stays on after the engine is off to keep cooling. Even in San Diego traffic I don't heat up, I run headers to.
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | OK.....just looked at their web site. Will definitely give one a try if I still have a problem. Thanks for the idea
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Yesterday we took the radiator out and back flushed it to be sure none of the crud from the block got caught inside. Must have mad a difference since it now idles at 181 degrees ... Happy truck! | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Your original problem of 195 degrees may have been caused by trapped air in the system that was alleviated by what you have done recently. I'm happy for you getting it to run cooler! I can't count how many times I have taken something apart, found nothing wrong, put it back together and everything was back to normal. When that happens, I still take full credit for my masterful mechanical abilities. Ya, right!
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | I had the same thought Carl. Could be but also back flushed the (new) rad which was installed before we cleaned the block and head.
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Truck home yesterday and he's very happy. Runs all day at 180 and lots more power due to valve replacement. Long journey but finally there  | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | "1000cfm! My farts push more air"
And now we know why you always work alone Hollow 65. | | |
